Hi all
I am having issues that this box seems to keep loosing the hdmi connection momentarily, if I pause, choose a different movie or even adjust the volume I am greeted with a no signal screen for 20- 30 seconds which is making it pretty much unusable at the moment.
i have tried numerous hdmi cables and inputs to no avail, my system has a 4k fire tv and ps4 pro both outputting 4k with no issue
any ideas?
(2020-06-20, 21:25)Alter48 Wrote: [ -> ]Please write how to change the file from the command line !? With which program, please step by step. I bought a 3D console for this, thanks to this review, and it says that 3D works out of the box! I am writing and reading through a translator.
3D SBS and Top/Bottom work out of the box.
We have been careful not to advertise any 3D MVC support yet as this is still experimental. We do not advertise support for this anywhere in marketing materials until this is stable.
If you are happy to run the experimental build, follow
https://discourse.osmc.tv/t/testing-linu...k-4k/84874 and then run:
sudo apt-get install --reinstall vero3-mediacenter-osmc=18.6.0-13.
(2020-06-20, 21:40)newstuart Wrote: [ -> ]Hi all
any ideas?
I would suggest opening a support request with the necessary logs.
https://osmc.tv/wiki/general/how-to-subm...t-request/
(2020-06-20, 21:41)Sam.Nazarko Wrote: [ -> ]If you are happy to run the experimental build, follow https://discourse.osmc.tv/t/testing-linu...k-4k/84874 and then run:
Before installing the test assembly, which assembly should stand
2020.06-1?
The assembly is installed, but I can’t roll back the codi using sudo apt-get install --reinstall vero3-mediacenter-osmc=18.6.0-13
(2020-06-20, 22:12)Alter48 Wrote: [ -> ]The assembly is installed, but I can’t roll back the codi using sudo apt-get install --reinstall vero3-mediacenter-osmc=18.6.0-13
What happens when you run the command?
(2020-06-20, 22:09)Alter48 Wrote: [ -> ] (2020-06-20, 21:41)Sam.Nazarko Wrote: [ -> ]If you are happy to run the experimental build, follow https://discourse.osmc.tv/t/testing-linu...k-4k/84874 and then run:
2020.06-1?
That is the base OS version, rather than the Kodi version, so this version number is not relevant here.
It turned out to roll back the codi, which I still have to turn on to view 3D?
How to check the test version?
(2020-06-20, 22:28)Alter48 Wrote: [ -> ]How to check the test version?
The easiest way is to check System Info in Kodi.
Checked 2020.05.04 test, code too 18.06 but movies do not start! What else have I not done?
(2020-06-20, 22:39)Alter48 Wrote: [ -> ]Checked 2020.05.04 test, code too 18.06 but movies do not start! What else have I not done?
2020.05.04 is not a known OSMC version.
I suggest starting a support request with debug logs.
build 2020.05.04 version 2020.06-1 when 3D is turned on, the signal disappears and there is no hardware 3D item
(2020-06-20, 22:49)Alter48 Wrote: [ -> ]build 2020.05.04 version 2020.06-1 when 3D is turned on, the signal disappears and there is no hardware 3D item
We need to see some logs.
Please open a support request
In general, everything worked out for me. True, it would be nice to suffer a little if all the information on this topic would be collected in one place and written in detail step by step, how to proceed with the user to install the test version and roll back Cody to the previous one.
I liked the 3D quality, in principle, quite at the level. Perhaps the best thing I have ever seen. The only thing is that if you set the Ultra HD resolution in the code itself in the system, then when you turn on 3D ISO, the resolution does not switch automatically and therefore the signal from the set-top box to the TV disappears.
So far, only one file does not open, I opened it using another console. He’s definitely working specifically Vero freezes on it and you have to reboot the console using the power interruption method.
I certainly still have other questions, but I will probably be asking them at your company forum.
