Full Version: How to compile libretro game-addons from source?
Hi there,
I've successfully compiled kodi 19 from source with some addons (tvh.pvr visualization.projectm etc..).
So for these addons it's simple.
git checkout addon (optionally switch to Matrix branch).
cd addon; mkdir build; cd build
cmake -DADDONS_TO_BUILD=visualization.projectm -DADDON_SRC_PREFIX=../.. -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=../../kodi19/addons -DPACKAGE_ZIP=1 ../../kodi19/cmake/addons
make
Now for flycast for example it doesn't work, I'm running cmake from the game.libretro.flycast/build directory:
$ cmake -DADDONS_TO_BUILD=game.libretro.flycast \
    -DADDON_SRC_PREFIX=../.. \
    -DCMAKE_BUILD_TYPE=Release \
    -DCMAKE_INSTALL_PREFIX=../../kodi19/addons \
    -DPACKAGE_ZIP=1 \
-- The C compiler identification is GNU 10.0.1
-- The CXX compiler identification is GNU 10.0.1
-- Check for working C compiler: /usr/lib/ccache/cc
-- Check for working C compiler: /usr/lib/ccache/cc - works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/lib/ccache/c++
-- Check for working CXX compiler: /usr/lib/ccache/c++ - works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Addon source tarball caching is enabled
-- ZIP packaging enabled (destination: /home/odroid/src/game.libretro.flycast/build/build/zips)
-- Building following addons: game.libretro.flycast
-- Overriding addon source directory prefix: /home/odroid/src
-- ---- Preparing general dependencies ----
-- No platform specific file /home/odroid/src/kodi19/cmake/addons/depends/linux/CMakeLists.txt found
CMake Error at CMakeLists.txt:456 (message):
  game.libretro.flycast did not match any of the supported addons.  A list of
  supported addons can be viewed by building the 'supported_addons' target.
  Addon definitions are loaded from ADDONS_DEFINITION_DIR
  (/home/odroid/src/kodi19/cmake/addons/addons).
-- Configuring incomplete, errors occurred!
See also "/home/odroid/src/game.libretro.flycast/build/CMakeFiles/CMakeOutput.log".
Any ideas?
I'm on Odroid XU4, so I want to compile them from source with so I can tweak the depends/Makefile with some optimized flags.
You can try my Kodi compilation scripts. For Odroid XU4 maybe you will need to change the build dependencies a bit. Even if you don't want to use my scripts the process is well documented and you can have a look inside the scripts to see the commands they invoke.
