Full Version: Starting Game, Exit Games, joystick?
• For MAME 2000, to start a local .zip game I have to press "menu" on the remote, then play. Any reason just "select" doesn't do anything?
• Is there a way to do this thru a controller?
To exit a game, currently have to use remote to "return", then select "stop" thru the CM.  How can one exit directly with the controller?
How do you make the left joystick function for up/right/left/down as well as the D-Pad, or is this possible?
Currently using :  (Xbox 360 controller, wired).
