2020-05-09, 07:14
Hi guys! I've been putting together thousands of movies in TMM recently, & finally had about everything I needed together, manually scraped, etc... I went into each movie & renamed folders such as "Featurettes" to "Extras" which stopped a bunch of junk being picked up in source updates & got everything to the point where doing a fresh scan would bring up everything just as I wanted it. Anyway, I figured I'd make the folder names more uniform & settled on making the folder settings:
${movieSet.title}\${title}${ (,edition,)} (${year}) [${videoCodec} ${videoFormat} ${videoBitDepth}bit${if movie.videoHDRFormat} HDR${else}${end}] [${audioCodec} ${audioChannels}]${ [,3dformat,]}
& the filename settings blank, as I wanted to keep the original names. This for the most part worked fine, but I've realized that it moved all the Extras files into the main folder, & then when I scan again, they come up as their own entries! I figure the program must know they're extras since it kept them... is there a way to re-do the rename or something so that it puts those files back into a separate folder? Or is there a way to just ignore them through TMM's knowledge of them (I suppose in the nfo)?
