Full Version: Omni202 - Fork of Omni 2.x with skinshortcuts support (for Leia)
OMNI202
This is a fork of the OMNI skin for Kodi called OMNI202 for its omnipresent menus and 202 as a reference to the version it is based on. Users of Mimic will recognize that it was the base for OMNI. OMNI202 is much more streamlined than Mimic, however, and doesn't have as many customisation options. Here's what you need to know:
- The main menu and submenus are accessible from every window. Press left from the main menu and everything will slide to the right, revealing the submenu.
- The main menu and info dialog menus use icons only. Although it may not be absolutely clear at first what some options do, you will quickly figure out what they are.
- Press right from the window content or scrollbar to access the media menu. Or press "m" on your keyboard or remote.
- Only keyboard and remote input are supported. Mouse input is entirely untested.
Forked from OMNI by braz96, based on v2.0.2 commit 6aac4343e5
https://github.com/braz96/skin.omni/tree...e328994855
Aim is to restore script.skinshortcuts and custom widgets functionality, with backported and personal future fixes and occasional feature additions.
If you would like to express your appreciation for this skin, please consider a donation to the XBMC Foundation. http://kodi.tv/contribute/donate/
Repo:
https://daedalusbln.github.io/repo
Github:
https://github.com/daedalusbln/skin.omni202
Keymap for touchscreens:
https://github.com/DaedalusBLN/skin.omni...screen.xml
Changelog:
OMNI202 v1.0.2
- VideoOSD: SeekBar dialog: Show movie/episode plot and title in pause menu. (Feature requested by user.)
OMNI202 v1.0.1
- Remove uppercase tags, as it messes up accentuation in certain languages.
- Fix ExtendedInfo integration.
- Backport: Disable Youtube lookups in info dialogs.
OMNI202 v1.0.0
- Test various commits to find a place to start and base the fork on.
- Rollback to v2.0.2 version bump commit for script.skinshortcuts integration and working custom widgets.
- Update addon.xml xbmc.gui dependency to v5.14.00
- Update variables.xml to fix weather bug
