I would like to know how to add support for different aspect ratio and ultrawide resolutions in addon skins, is this possible without rewriting the width structure in all files creating another folder ex. 21x9?
BR
Mariusz
Yes, have a look at Estuary addon.xml as it already does this
xml:
<extension point="xbmc.gui.skin" debugging="false">
<res width="1920" height="1440" aspect="4:3" default="false" folder="xml" />
<res width="1920" height="1280" aspect="3:2" default="false" folder="xml" />
<res width="1920" height="1200" aspect="16:10" default="false" folder="xml" />
<res width="2040" height="1080" aspect="17:9" default="false" folder="xml" />
<res width="1920" height="1080" aspect="16:9" default="true" folder="xml" />
<res width="2560" height="1080" aspect="21:9" default="false" folder="xml" />
<res width="2338" height="1080" aspect="19.5:9" default="false" folder="xml" />
<res width="2160" height="1080" aspect="18:9" default="false" folder="xml" />
</extension>
The skin needs to be written in a way that is responsive to aspect ratio changes though -- other than Estuary, most skins will break if you change the aspect ratio.
In addition,
i would tend to avoid posx, posy tags, and use left,right,bottom,top values if possible instead.
Also use percentage values, instead of 'fixed' if possible.
e.g. instaed of
<height>270</height> , use
<height>25%</height>
I case some finetuning needed, you also can work with some booleans
like
String.IsEqual(Skin.AspectRatio,**)
String.IsEqual(System.ScreenWidth,**)
String.IsEqual(System.ScreenHeight,**)
Thank you for your answers. I`m looking at the estuary skin solution but is it applicable for custom skins within my addon script?
(2020-05-14, 14:04)crashnburn Wrote: [ -> ]Looking for a LIGHT / Minimalist SKIN
There is no need to post your text in all bold letters.
We can read the normal font just fine.
Also, the linked thread in your signature is quite outdated (2016).
(2020-05-19, 19:20)Klojum Wrote: [ -> ] (2020-05-14, 14:04)crashnburn Wrote: [ -> ]Looking for a LIGHT / Minimalist SKIN
My bad.. I should've bolded whats key. Sig will have to check.
- Looking for a LIGHT / Minimalist SKIN
(I use Music Bee or Foobar on Windows) that
- Works & LEVERAGES High Res Screen - 1080p and/ or 4K
- To
SHOW more Data i.e. Smaller Font/ Text and
more Items in the
List VIEW at any given time.
