2020-05-11, 14:21
Hi all,
I have a problem with a new install. I'm running 18.7 on an i5 7400/1050Ti/ 8 Gb RAM on Windows 10.
I recently did a clean install of Windows and Kodi, using up to date graphics drivers.
I have the system running through a current model Denon amp, through to an LG OLED, using brand new premium high speed HDMI cables with ethernet (HDMI 2.1 capable).
Periodically, Kodi (and at least one other app) will cut video/audio signal for about 2-3 seconds causing HDMI to reestablish handshake. During that period, my TV even displays 'no signal'. This happens regardless of whether video is currently playing, or whether or not the UI is idle, and whether or not Kodi is displaying in a window, fullscreen window, or fullscreen. It doesn't even matter if the Kodi window isn't in focus, the entire video signal of the desktop is lost temporarily, causing HDMI to reestablish handshake.
This only occurs when:
- Kodi is open, regardless of which external app/player I'm using.
- Playing back videos through Windows default 'Films and TV' app, even when Kodi is closed.
When I close Kodi and run MPC-HC using MadVR, no signal cut occurs while playing the same videos across a variety of codecs (and I've played these videos in MPC for hours without interruption). I can also confirm it doesn't happen while playing intensive games for hours. For instance, I played Doom Eternal for 4 hours straight last night without a single hiccup.
At first, I thought it had something to do with Steam running in the background, so I killed the process, and stopped it from starting with Windows, and restarted - no change.
I have no additional third party programs running in the background.
I've also done clean installs of Kodi numerous times with different versions - no change.
At this point I'm completely stuck. I have no idea what to do, and it's making my HTPC essentially useless. I'm really hoping someone here can help me out.
Here is my log. During this record, the described phenomenon happened twice during playback.
https://paste.kodi.tv/ibotahebef.kodi
EDIT: More comprehensive log attached in below replies.
Considering this is only happening when Kodi is open or when playing back using Windows Media player (even when Kodi is closed), could this be a codec issue?
I'm really hoping someone here can help me out, because otherwise my HTPC may as well be an expensive paperweight.
