Full Version: Leia v18.6 Unable to Fast Forward TV recordings with any update after 20200505 ?
Hi, I've lost the ability to FF/RW any TV recordings. update from 5th May was OK but any daily releases since of 18.6 are not working. Back end is ArgusTV.
I've reverted to working version at the moment (KodiSetup-20200505-f0bc4746-Leia-x64.exe)
Has anybody else come across this or have any solution?
Cheers
@i0zjh02 there was a change recently where the addon needs to report if a stream is realtime or not. I will send you a link to an addon build later today if you could test it?
Can you try this version of the addon?
https://jenkins.kodi.tv/job/kodi-pvr/job...-3.5.6.zip
(2020-05-15, 10:15)phunkyfish Wrote: [ -> ]@i0zjh02 there was a change recently where the addon needs to report if a stream is realtime or not. I will send you a link to an addon build later today if you could test it?
Thanks, yes if course if you send me the link I will test when I'm home later
Cheers
(2020-05-15, 11:45)phunkyfish Wrote: [ -> ]Can you try this version of the addon?
Perfect, now working ok for me with your updated version :-)
Thanks for very quick responce !!
Great, I will get that merged in the next few days and release officially.
