Full Version: [WINDOWS] Unofficial third-party nightly builds for the community (Notification only)
Upped Rev19484 Smile
The same problem with Rev19484
dyt72 Wrote:The same problem with Rev19484
This is not the thread to post about problems...
ok, forget it then and sorry...
Upped Rev19493 Smile
Upped Rev19500 Smile
Something's strange with the previous build.
I deleted a tv show folder (Stargate Atlantis) since it's over.
Then I removed it from the database ('C' on the folder and remove from library).
But if I update the library, XBMC brings back a "Stargate Atlantis" folder on the screen.
Looks like it keeps some data in cache.
(i'm using windows vista and xbmc is installed in portable mode)
I'm trying rev 19500 right now.
Rev-19503 Also available with XBMC Updater.
Upped Rev19569 Smile
Upped Rev19582 Smile
Upped Rev19607 Smile
Upped Rev19632 Smile
NSIS Error: Installer integrity check has failed.
I've redownloaded several times, so I'm pretty sure it's not an incomplete download.
natew Wrote:NSIS Error: Installer integrity check has failed.
Use the XBMC Updater to grab it then.
