That's how it's meant to work if I remember correctly. As long as it's not dropping below that all is fine.
Rev 22975 DX for me didn't play the videos at the right resolution. gl works fine for me though.
i have the 8600m gt 256mb
what is the difference between gl and dx versions ?
gl=OpenGL build, dx=DirectX build
Gonna try all these builds 7 report back on Intel X4500HD
Sorry for triple post but here is my feedback.
Specs:
intel Q6600 quad core running @ 3.3Ghz
4 GB dual channel Ram
Built In Intel X4500HD
SSD 65GB
Running Aeon Hitched & installed both dx & gl versions on top so not a clean install :
DX (23069) v GL(23069)
IDEL_Main menu--------------------------------------------
FPS: 60 v 100
CPU Usage: 6% v 5%
IDEL_Movies Menu------------------------------------------
FPS: 30 v 38
CPU Usage: 7% v 8%
Comments: DX even though running at lower Frames is much smoother while GL jitters a lot when moving around menus & especially scrolling in movies using cover flow.
Im sticking with this build of Direct x.
Thanks for the info, but this is the wrong thread for that. Look for Azido's DX thread.
azido Wrote:hitchers?
Isn't "Azido" what you get when you do a git clone of "Hitcher"?
