Hello,
I try pvr-ip and I make package
https://github.com/kodi-pvr/pvr.iptvsimple. The package installed successfully and the list configuration went well.
The problem is that I use the CPU at 4 * 100% for watching video. Is there a way to stop having 100% cpu (low resolution or acceleration GL)?
Kinds regard
Do you hade hardware acceleration enabled in kodi?
In kodi, the video work work well, I use opengles
I have a small latency link to the disc but nothing serious : )
So you don’t have a problem?
(2020-05-19, 08:54)phunkyfish Wrote: [ -> ]So you don’t have a problem?
In fact, it's very slow, I can watch TV at 0.75x speed.
It's still weird, I play movies in 4K without worries, but I can't watch TV in [H264] 1920x1080?
I'm on an A57 cortex and Maxwell gpu: x. I may have compiled the module wrong?
It’s sounds like your hardware acceleration is misconfigured or not working.
(2020-05-23, 22:18)phunkyfish Wrote: [ -> ]It’s sounds like your hardware acceleration is misconfigured or not working.
Hello, I found why the TV was not working.
High definition videos on the trouble of passing.
1920x816 with 25 fps just pass
1920x1080 with 24 FPS offset
TV: 1920x1088 50FPS huge lag.
I do not know if we can decrease the resolution of output like in gstreamer?
I’m afraid I don’t know. But there are settings in kodi around adjusting refresh rate.
There is probably a better part of the forum to ask this question.
