Full Version: Kodi 18.6 Xbox One X :in progress movies always lost
Each time I start a movie, then quit and come back all progress is lost and I have to manually search the position I was in the movie the last time I quit...
Obviously it's kind of annoying...
Anyone knows this bug? Or is it something I haven't done?
thanks
(2020-05-21, 10:45)nico1375 Wrote: [ -> ]Each time I start a movie, then quit and come back all progress is lost and I have to manually search the position I was in the movie the last time I quit...
So the resume points are not stored in, or retrieved from, the video database.
Perhaps you can provide a debug log (wiki) from whever that is happening for a better insight in the things running on your Kodi box.
I've noticed that if I pause the film and shut down Kodi or the Xbox, then the resume point is lost, but if I stop the film before shutting down then it's saved.
Thanks for both inputs...
I will try @Filmbuff 's suggestion as a workaround, and @Klojum yes I suspected it had to do with not writing some info... I will investigate
(2020-05-21, 12:29)Filmbuff Wrote: [ -> ]I've noticed that if I pause the film and shut down Kodi or the Xbox, then the resume point is lost, but if I stop the film before shutting down then it's saved.
That is correct. There is no auto-save function for the current video.
