2020-05-21, 23:58
https://github.com/jdf76/plugin.video.yo...-630654903
I used JDownloader 2 to extract the 2160p HDR stream and demux it into a file. When I try to play the file in Kodi, on a variety of platforms, Windows 64-bit , AFTV 4K (Android ARM), Vero 4K+ (OSMC), HDR mode is not triggered.
When I play it in MPC-HC, I can get HDR mode.
Here is the MediaInfo:
General
Unique ID : 6796862651930518936958579878903024684 (0x51D07339696AECAF82FA8EF0A3A0C2C)
Complete name : (1920p_30fps_VP9 HDR-128kbit_AAC).mkv
Format : Matroska
Format version : Version 4
File size : 1.37 GiB
Duration : 9 min 7 s
Overall bit rate : 21.5 Mb/s
Writing application : Lavf58.39.101
Writing library : Lavf58.39.101
ErrorDetectionType : Per level 1
Video
Format : VP9
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_VP9
Duration : 9 min 6 s
Width : 3 840 pixels
Height : 1 920 pixels
Display aspect ratio : 2.000
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color pri : Display P3
Mastering display luminance : min: 0.0099 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000
Maximum Frame-Average Light : 300
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 SPF)
Compression mode : Lossy
Title :
Default : Yes
Forced : No
Any thoughts would be appreciated.
General
Format : Matroska
Video
Format : VP9
Codec ID : V_VP9
Color space : YUV
Language : English
Default : Yes
Forced : No
Audio
Format : AAC LC
Codec ID : A_AAC-2
Title :
Default : Yes
Forced : No
