Full Version: Switch between video streams by key
Since i use the Blu-ray menu feature with Java i have sometimes the issue that when a movie starts playing the lower resolution stream e.g. 720p is selected and playing. Then i have to go to "m" player contros, settings, video settings, video sream to change it to e.g. 1080p stream. I did not find a key for instand switch to the next video stream.
Alternative solution could be that if Kodi detect several video streams with different resolutions to select always the best stream.
