Full Version: Kodi crashes since 18.6 on my Xbox ONE
I cannot play any mkv file with Kodi since v18.6, even with v18.5. It crashes I after I push the play button.
v18.5 worked well...
How can I find the cause of crash?
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
4.Upload the log to Kodi Paste Site manually or use the Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file (wiki)
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
Thank you for the fast answer.
Link to the log: http://paste.kodi.tv/xeluhaxihe
Can anybody help me?
Finally I reinstalled Kodi and now it works well.
Thread marked solved.
