Full Version: How to know path of my add on?
Hello
I installed my custom "add on" and it run as
 <onclick>ActivateWindow(Videos,addons://sources/video/)</onclick>
then it shows my video "add on" list window.It works fine.
However, I would like to run my specific video addon like this
<onclick>ActivateWindow(Videos,addons://sources/video/myaddon/)</onclick>
to do that, I need my addon path (If I have correct)
Can you advise me how to know the path of video app?
Thread moved to addon development.
if you want to run a plugin from within a skin, you need to use the 'addon id'.
for instance, this will run the youtube plugin:
xml:
<onclick>ActivateWindow(Videos,plugin://plugin.video.youtube/)</onclick>
(2020-05-23, 12:41)ronie Wrote: [ -> ]if you want to run a plugin from within a skin, you need to use the 'addon id'.
xml:
Appreciate. It works.
