Hi all and Happy Memorial Day! I have been having an odd issue with my HdHomerun PVR setup with Kodi, where the channel guide has some channels that are missing on one instance of Kodi, but when i compare it to another, they are all there as expected. So i have 3 separate computers running Kodi, 2 have Leia and another has Jarvis. Jarvis and the 2nd Leia all channels come in as expected, but the 1st Leia (which is my primary watching system) does not get all the channels. I'm also noticing that the channels numbers are off as well between the 1st and 2nd Leia, despite the skin and version being the same. I did try uninstalling and reinstalling the PVR client on 1st Leia but that didn't make a difference. Are there any library files i can manually alter that might clear this out so i can start fresh with it, besides rebuilding everything from scratch? Thanks
(2020-05-25, 15:44)mknabster Wrote: [ -> ]Hi all and Happy Memorial Day! I have been having an odd issue with my HdHomerun PVR setup with Kodi, where the channel guide has some channels that are missing on one instance of Kodi, but when i compare it to another, they are all there as expected. So i have 3 separate computers running Kodi, 2 have Leia and another has Jarvis. Jarvis and the 2nd Leia all channels come in as expected, but the 1st Leia (which is my primary watching system) does not get all the channels. I'm also noticing that the channels numbers are off as well between the 1st and 2nd Leia, despite the skin and version being the same. I did try uninstalling and reinstalling the PVR client on 1st Leia but that didn't make a difference. Are there any library files i can manually alter that might clear this out so i can start fresh with it, besides rebuilding everything from scratch? Thanks
Hi! I believe your symptoms match a fix that was put into Kodi 18.7. Suggest installing 18.7 if you haven't already, and then do a "Clear Data" in PVR & Live TV, that should clear it up. If you want to verify it will work first, check the Channels area, the missing channels should be there, but not in the EPG.
Hope this helps!
