2020-05-25, 16:06
Long time user of KODI on windows and absolutely loving it. Just dipped my toe into the world of raspberry pi and got a Pi 4B to use it as a mediacenter, light retro gaming and steamstreaming from my main computer in my bedroom. After some ruminating and testing I decided to just go with Raspbian Buster and I installed KODI, steamlink and retropie with no problems. (Well, had to figure out HOW to do it first, but that's another story. ) After being surprised that it was not as easy as I expected to connect the xbox controller via Bluetooth (had to to it via xpadneo to get it to work properly) I could see it work well with steamlink and retropie.
So in my naivety I thought KODI would be just as good to go. No dice however. It's like it's not seeing it at all (Also tried it with a USB cable and still no go) and when I try to use the configuration screen for the KODI controller absolutely nothing happens besides it timing out. After some googling I tried to install the kodi-peripheral-joystick via sudo apt install (I am assuming that is how you go about it ) and I see it listed under addons and it seems to be there I always time out on the configuration screen.
So I am at my wits end and seeking help.
