2020-05-28, 17:41
2020-05-28, 17:41
2020-05-28, 21:43
@abigor
Can't answer your question, but be aware that DVD and Absolute Order are partly broken at TVDB so it would be safest if you stick with Aired Order.
2020-05-30, 09:58
EDIT: sorry, I did not understand the question exactly before I answered...
you can choose between aired order and dvd order in tmm (but we do not support absolute order, since that would our internals)
to enable that you have to "mark" each show which order type to use. either do that in the "data sources" settings, or mark them individually and choose the "edit menu" -> "Change selected episodes to dvd order".
but be aware - this could mess up your library
- netflix order or others are not supported by the tvdb api
