hello from Alicante, Spain:
i'm a newbie on kodi, excuse me if i'm wrong to post here my problem.
I have kodi 18.6 under OpenSuse Leap 15.1. Kodi runs great all except video. I can hear it but i dont see it.
In the registry says :
2020-06-01 14:50:47.687 T:140341562808064 NOTICE: Opening stream: 0 source: 256
2020-06-01 14:50:47.687 T:140341562808064 NOTICE: Creating video codec with codec id: 27
2020-06-01 14:50:47.687 T:140341562808064 DEBUG: CDVDVideoCodecFFmpeg::Open() Unable to find codec 27
2020-06-01 14:50:47.687 T:140341562808064 ERROR: CVideoPlayerVideo::OpenStream - could not open video codec
2020-06-01 14:50:47.687 T:140341562808064 WARNING: OpenStream - Unsupported stream 0. Stream disabled.
2020-06-01 14:50:47.687 T:140341562808064 NOTICE: Opening stream: 1 source: 256
Otherwise put the kodi log :
Thanks to all for your help.
https://paste.kodi.tv/kebigowipe.kodi
xaxuthekid - your install contains
banned addons (wiki) in violation of the
forum rules (wiki) that you accepted and agreed to abide by when you signed up here. Please actually go and read the
piracy policy (wiki) section of it.
All of the list below are banned and must be removed before any support for issues is available here for the install:
2020-06-01 14:50:26.716 T:140343298103872 NOTICE: ADDON: plugin.video.f4mTester v2.7.2 installed
2020-06-01 14:50:26.716 T:140343298103872 NOTICE: ADDON: plugin.video.1x2 v1.0.27 installed
2020-06-01 14:50:26.716 T:140343298103872 NOTICE: ADDON: program.plexus v0.1.8 installed
2020-06-01 14:50:26.716 T:140343298103872 NOTICE: ADDON: repository.Diamond-Wizard-Repo v6.3 installed
2020-06-01 14:50:26.717 T:140343298103872 NOTICE: ADDON: repository.Maniac v1.0.1 installed
2020-06-01 14:50:26.717 T:140343298103872 NOTICE: ADDON: script.video.F4mProxy v2.8.8 installed
The forum moderators have determined that
banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
(2020-06-01, 17:24)DarrenHill Wrote: [ -> ]@xaxuthekid - your install contains banned addons (wiki) in violation of the forum rules (wiki) that you accepted and agreed to abide by when you signed up here. Please actually go and read the piracy policy (wiki) section of it.
The forum moderators have determined that banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
Sorry !!!
Here you've got a new one.
https://paste.kodi.tv/tabaqagifa.kodi
(2020-06-01, 17:34)xaxuthekid Wrote: [ -> ]Here you've got a new one.
2020-06-01 15:31:09.866 T:140511537494592 NOTICE: ADDON: repository.Diamond-Wizard-Repo v6.3 installed
2020-06-01 15:31:09.866 T:140511537494592 NOTICE: ADDON: repository.Maniac v1.0.1 installed
Last chance... Anything in orange in your kodi.log is considered piracy crap.
You've missed a couple of the banned repos:
(2020-06-01, 17:37)DarrenHill Wrote: [ -> ]You've missed a couple of the banned repos:
Last reply... I'm really sorry.
I think i delete all add-ons.
thanks again !!!
https://paste.kodi.tv/karubiyowo.kodi
Probably because of an unsupported ffmpeg version your distro provides. You have ffmpeg 4.2.2 installed. IIRC Kodi 18 needs 4.0.4
Try downgrading ffmpeg and see if that fixes something.
(2020-06-01, 19:45)DaVu Wrote: [ -> ]Probably because of an unsupported ffmpeg version your distro provides. You have ffmpeg 4.2.2 installed. IIRC Kodi 18 needs 4.0.4
Hello DaVu, thanks for your answer.
I downloaded and installed ffmpeg 4.0.5. but Kodi still says thats using 4.2.2.
How can downgrade it ?
Thanks again
I don't know OpenSuse. So i can't help much in that regard. Probably compile Kodi with configuring Kodi with that switch included. -DENABLE_INTERNAL_FFMPEG=ON
or try using Kodi 19 if that already matches your needs. Some add-ons might not work currently. So please be aware that this version is pre-alpha.
you'll have to refer to opensuse, since they provide this unsupported build.
Thanks to all for your support.
I made a new kodi from source code with the option that you said me.
After installing a great amount of devel packages, and resolving some errors, always following the excepcional manual, I resolve the problem and works!!!
Thanks again. you're greats.
