Full Version: "PVR-Mgr not starting - 0%", DVB-Viewer client V3.7.11 with Kodi 18 not working
Hi.
I'm new here and do have problems with my Kodi having DVB-Viewer-Plugin.
Here my configuration:
PC1: Windows 10 pro with DVB-Viewer pro v6.1.6.8 working fine and DVBViewer Media Server V2.1.6.1 working fine, serving Digital Devices twin tuner.
PC2: Windows 10 pro DVB-Viewer pro v6.1.6.8 working fine, I can connect to PC1 and watch live TV with DVB-Viewer.
        Kodi 18.7.0.0 is also installed on PC2, DVB-Viewer Plugin Manuel Mausz V3.7.11 as PVR-Client
m< problem: starting my Live-TV on Kodi 18.7.0.0, I only can read above on my Screen:
PVR-Manager is starting: 0%
-> but he doesn't
I searched the internet: often I read: channel list on PC1 could be damaged -> so I deleted and rescanned all channels.
-> not my solution. I began writing this post and uuuuups: it worked. I deleted my work and watched TV.
-> but some later, I did do nothing: my problem is the same again: PVR-Manager is not starting.
Do you know, what I could do now?
Thanks and kind regards,
Sven Mueller
(2020-06-02, 00:53)muelv Wrote: [ -> ]Hi.
-> but he doesn't
Sven Mueller
I now realize: without changing something: it works (I can see "54 channels, 1 recording" on my screen, but some minutes later, he sais "0 channels, no recordings", so I think, he is sometimes loosing the connection? I don't have no virus scanners active (only defender)... Someone knows about this problem? Thank you, Sven Mueller
(2020-06-02, 01:33)muelv Wrote: [ -> ]
-> but he doesn't
Sven Mueller
go into settings of dvbviewer and enter your password again and it may work
It's always the same. Upload a debug log first.
