I had the same problem. I tweaked the default.py script slightly and got it to work. Thanks rwparris for building the plugin!!!
Here's the fix I made:
1: Open the default.py file (from the Live Music Archive folder) in your text editor
2: Change line 56 to the following (one Tab in front):
p=re.compile('<li><a href="(.+?)">(.+?)</a>.+?<a href="(.+?)">(.+?)</a>')
3: Change line 79 to the following (two Tabs in front):
addDir(bandList[i][1]+' ('+bandList[i][3]+')',bandList[i][2],4)
[EDITED TO ADD:]
4: Change line 88 to the following (two Tabs in front):
p=re.compile('href="(.+?)">.*(Live at.+?)</a>')
Now your band list should include the # of shows that are available, and they should work when you select them.
If you prefer not to see the # of shows, change line 79 to the following instead of the code listed in step 3 above (still two Tabs in front):
addDir(bandList[i][1],bandList[i][2],4)
It seems the necessary link moved from the band's name to the (# shows) link. I just had to tweak the regular expression, and the handling to match. Also, fixed the line in Step 4 which was breaking some show lists.
Remaining issue: The plug-in works for me now with all the individual file types, but not with the m3u playlists. XBMC says there's an error, but no details, and I'm TOTALLY new to python and xbmc plugins - although I did play around with it a little with no success.
Maybe someone else (rwparris, maybe?) has ideas as to why it chokes on building links for the m3u playlists?
Here is the full default.py file, in case you have difficulty finding the specific lines and want to just replace the whole thing:
[INCLUDES LATER EDIT FOR SHOW LIST CORRECTION]
#Live Music Archive (archive.org) default.py
#by rwparris2
import urllib,urllib2,re
import xbmcplugin,xbmcgui
from BeautifulSoup import BeautifulStoneSoup, BeautifulSoup
xbmcplugin.setContent(int(sys.argv[1]), 'songs')
xbmcplugin.addSortMethod(int(sys.argv[1]), 7)
xbmcplugin.addSortMethod(int(sys.argv[1]), 9)
def getLink(site):
req = urllib2.Request(site)
req.add_header('User-Agent', 'Mozilla/5.0 (Windows; U; Windows NT 5.1; en-GB; rv:1.8.1.14) Gecko/20080404 Firefox/2.0.0.14')
response = urllib2.urlopen(req)
link=response.read()
response.close()
return link
def addDir(name,url,mode):
u=sys.argv[0]+"?url="+urllib.quote_plus(url)+"&mode="+str(mode)+"&name="+urllib.quote_plus(name)
ok=True
liz=xbmcgui.ListItem(name)
liz.setInfo( type="Music", infoLabels={ "Title": name } )
ok=xbmcplugin.addDirectoryItem(handle=int(sys.argv[1]),url=u,listitem=liz,isFolder=True)
return ok
def addLink(name,url,artist,album,track):
ok=True
liz.setInfo( type="Music", infoLabels={"Title": name,"Album":album,"Artist":artist, "Track":track } )
ok=xbmcplugin.addDirectoryItem(handle=int(sys.argv[1]),url=url,listitem=liz)
return ok
def get_params():
param=[]
paramstring=sys.argv[2]
if len(paramstring)>=2:
params=sys.argv[2]
cleanedparams=params.replace('?','')
if (params[len(params)-1]=='/'):
params=params[0:len(params)-2]
pairsofparams=cleanedparams.split('&')
param={}
for i in range(len(pairsofparams)):
splitparams={}
splitparams=pairsofparams[i].split('=')
if (len(splitparams))==2:
param[splitparams[0]]=splitparams[1]
return param
def getBandList(link):
bandList=[]
match=p.findall(link)
for band in match:
bandList.append(band)
return bandList
def alphList(bandList,letter):
alphList=[]
if letter=='0':
num='.0123456789'
for n in range(0,10):
for i in range(len(bandList)):
if bandList[i][1][0]==num[n]:
alphList.append(bandList[i])
else:
if bandList[i][1][0]==letter:
return alphList
def showBandList(bandList):
i=0
while(i<len(bandList)):
i+=1
return bandList
def getShowList(link):
tree=BeautifulSoup(link)
d=tree.findAll('a', 'titleLink')
showList=[]
for i in range(len(d)):
match=p.findall(str(d[i]))
for show in match:
showList.append(show)
for n in range(len(showList)):
s=re.compile('<span class="searchTerm">|</span>')
tmp=str(showList[n][1])
tmp=s.sub('',str(showList[n][1]))
addDir(str(n)+'. '+tmp,showList[n][0],6)
def getPageNumber(link):
p=re.compile(' <a href=".*page=(.+?)">Last</a>')
for pageNumber in match:
return pageNumber
def getFileTypes(url):
#list filetypes
p=re.compile('/details/(.*)')
match=p.findall(url)
for name in match:
temp= 'http://www.archive.org/download/'+name+'/'+name+'_files.xml'
link=getLink(temp)
tree=BeautifulStoneSoup(link)
shn=tree.findAll('file', attrs= {"name" : re.compile('(.+?\.shn$)')})
m3u=tree.findAll('file', attrs= {"name" : re.compile('(.+?\.m3u$)')})
flac=tree.findAll('file', attrs= {"name" : re.compile('(.+?\.flac$)')})
mp3=tree.findAll('file', attrs= {"name" : re.compile('(.+?64kb\.mp3$)')})
vbr=tree.findAll('file', attrs= {"name" : re.compile('(.+?vbr\.mp3$)')})
if len(m3u)>0:
addDir('.m3u Playlists',temp,7)
if len(flac)>0:
addDir('1. Flac Files',temp,7)
if len(mp3)>0:
addDir('2. VBR mp3',temp,7)
if len(vbr)>0:
addDir('3. 64kB mp3',temp,7)
if len(shn)>0:
addDir('1. Shorten Files',temp,7)
def getTracks(url,rx):
p=re.compile('(http://www.archive.org/download.*)/.*')
for name in match:
temp=name
link=getLink(url)
trackList=tree.findAll('file', attrs= {"name" : re.compile(rx)})
for i in range(len(trackList)):
url=temp+'/'+trackList[i]['name']
name=trackList[i].title.contents[0]
artist=trackList[i].creator.contents[0]
album=trackList[i].album.contents[0]
track=trackList[i].track.contents[0]
site='http://www.archive.org/browse.php?collection=etree&field=%2Fmetadata%2Fcreator'
#site='file:///C:/Program Files/XBMC/plugins/music/archive.org_del.later/artistList.php.html'
params=get_params()
url=None
name=None
mode=None
try:
url=urllib.unquote_plus(params["url"])
except:
pass
try:
name=urllib.unquote_plus(params["name"])
except:
pass
try:
mode=int(params["mode"])
except:
pass
if mode==None or url==None or len(url)<1:
addDir('Artists A-Z',site,0)
addDir('Browse all Artists',site,1)
if mode==0:
addDir('0-9, et al.','0',3)
bet='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
for i in range(0,26):
addDir(bet[i],bet[i],3)
if mode==1:
link=getLink(site)
bandList=getBandList(link)
if mode==2:
print 'search'
if mode==3:
link=getLink(site)
bandList=alphList(bandList,url)
if mode==4:
link=getLink('http://www.archive.org'+url)
pageNumber=getPageNumber(link)
if pageNumber==None:
getShowList(link)
else:
for i in range(1,int(pageNumber)+1):
addDir('Page '+str(i),url+'&page='+str(i),5)
if mode==5:
getShowList(link)
if mode==6:
getFileTypes(url)
if mode==7:
if name=='.m3u Playlists':
for name in match:
temp=name
link=getLink(url)
for i in range(len(m3u)):
addLink(m3u[i].format.contents[0].string,temp+'/'+m3u[i]['name'],"","")
elif name=='1. Flac Files':
getTracks(url,'(.+?\.flac$)')
elif name=='1. Shorten Files':
getTracks(url,'(.+?\.shn$)')
elif name=='2. VBR mp3':
getTracks(url,'(.+?vbr\.mp3$)')
elif name=='3. 64kB mp3':
getTracks(url,'(.+?64kb\.mp3$)')
'''if mode==8:
for name in match:
temp=name
link=getLink(url)
for i in range(len(flac)):
url=temp+'/'+flac[i]['name']
name=flac[i].track.contents[0]+'. '+flac[i].title.contents[0]
addLink(name,url)'''
xbmcplugin.endOfDirectory(int(sys.argv[1]))
