2020-07-04, 12:15
Pages: 1 2
2020-10-27, 01:28
Hi - I had issues with my ratings for the UK too, so every so often did a few minor updates to the database directly:
You can use SQLiteSpy (or another db editor that can read SQLite3 files) & open the kodi db
%AppData%\Roaming\Kodi\userdata\Database
Then I just check for any others that didn't match & might need updating manually by running these:
sql:
UPDATE movie SET C12 = replace(C12, 'Rated ', 'UK:' ) WHERE c12 LIKE 'Rated%';
UPDATE tvshow SET C13 = replace(C13, 'Rated ', 'UK:' ) WHERE c13 LIKE 'Rated%';
UPDATE movie SET C12 = '' where c12='Rated';
UPDATE tvshow SET C13 = 'UK:PG' WHERE c13 = 'TV-PG';
UPDATE tvshow SET C13 = 'UK:12' WHERE c13 = 'TV-14';
UPDATE tvshow SET C13 = 'UK:15' WHERE c13 = 'TV-MA';
UPDATE tvshow SET C13 = 'UK:PG' WHERE c13 = 'TV-G';
UPDATE tvshow SET C13 = 'UK:U' WHERE c13 = 'TV-Y';
UPDATE tvshow SET C13 = 'UK:U' WHERE c13 = 'TV-Y7';
sql:
select idmovie,idfile,c00,c09,c12 from movie where c12 not in ('UK:U','UK:PG','UK:12','UK:12A','UK:15','UK:18')
select idshow,c00,c13 from tvshow where c13 NOT in ('UK:U','UK:PG','UK:12','UK:12A','UK:15','UK:18')
2021-04-08, 18:25
Im also having probs using gb as country and all i get is NR any possiblilty of a quick demo video showing what needs to go where and how to input the values please?
Update solved many thanks
2023-01-30, 14:44
Hi can you let me know what you did to solve the issue? Thanks
2023-02-01, 21:22
What works for me is to use the following options
Preferred certification country gb
Certification Prefix UK:
in the configuration for instance of
The Movie Database Python
The MovieDBHelper
TMDb TV Shows
The MovieDBHelper
TMDb TV Shows
2023-02-02, 20:43
(2023-02-01, 21:22)robbie599 Wrote: [ -> ]What works for me is to use the following options
The MovieDBHelper
TMDb TV Shows
Same for me thats the method I use
Pages: 1 2
