Full Version: Movie Scraping problems
Full debug log
I have a clean Movie folder with two Starwars Movies (Episode 1 and 2).
I have tried the following namings with Library cleaning between each attempt, changed the scraper between The universal og The Movie DB.
Star Wars Episode I
Star Wars Episode 1
Star Wars Episode 1 1999
Star Wars Episode I The Phantom Menace
Star Wars Episode 1 The Phantom Menace
Star Wars Episode I The Phantom Menace (1999)
Star Wars: Episode I - The Phantom Menace (1999)
How difficult is it to add movies with KODI?
(2020-06-07, 16:15)aCeTotal Wrote: [ -> ]How difficult is it to add movies with KODI?
Easy, once you fix your settings. Check item 1d here... https://forum.kodi.tv/showthread.php?tid=336969
The scraper will never find a movie named... FindMovie: Searching for 'Star.Wars.Episode.I.The.Phantom.Menace.1999.2160p.BluRay.REMUX.HEVC.TrueHD.7.1.Atmos-FGT'
Also, you would be safer to name the movie as shown at TheMovieDB... https://www.themoviedb.org/movie/1893-st...tom-menace
Finally, disabling video tags fixed it. Thank you. Smile
Thread marked solved.
