Full Version: How to enlarge the mouse ?
I installed kodi-18.7-Leia-x64 and a small mouse cursor, and in black, barely see it on the TV screen
How do I increase my mouse cursor?
How do I change its color to white?
Looks fine to me, a screenshot and log file would give us more info.
(2020-06-09, 13:09)05007il Wrote: [ -> ]How do I increase my mouse cursor?
Sorry, but we're not yet senile here.
Do you still have your KodiCat wizard installed?
If so, do not expect further support, just like with your previous topic. Read our forum rules (wiki).
And don't create another new topic on this forum for your mouse cursor problem.
(2020-06-09, 13:30)Klojum Wrote: [ -> ]
i am know you are not senile
i removed the KodiCat wizard
You explained to me very well before " Such wizards have no support on this forum as per our forum rules "
In the first post I didn't know I was breaking the rules
So I removed the KodiCat wizard, installed a clean kodi-18.7-Leia-x64, but still the small mouse cursor that i see on the TV screen 75 "so at least I would like to explain to me how to change its color to white
I respect and fully understand why the previous question was removed
sorry abute thay
(2020-06-09, 17:28)05007il Wrote: [ -> ]i am know you are not senile
sorry abute thay
I posted a screenshot of the default mouse cursor, I wouldn't consider it small. You're going to have to give us more information if you want help, a screenshot & log file would be a good start.
(2020-06-09, 17:28)05007il Wrote: [ -> ]i removed the KodiCat wizard
Thanks for that.
Kodi features a 10-foot user interface for use with televisions and remote controls. Operation with a mouse is supported on some skins, and the pointer would be retentive to the resolution and skin chosen. Given that you seem to have a too small pointer icon, would indicate a fairly high res screen, and perhaps a remote control might be betterl suited. The actual pointer icon can be located in the 'Textures' file of the skin, editing is possible. Skinning Manual (wiki)
So if the wizard has been removed, you should get a default sized cursor again. Right?
(2020-06-09, 17:49)Klojum Wrote: [ -> ]So if the wizard has been removed, you should get a default sized cursor again. Right?
it is correct
for any one using kodi estuary (genuine based skin)
Pointer.xml
<?xml version="1.0" encoding="UTF-8"?>
<window>
    <controls>
        <control type="image" id="1">
            <description>Pointer</description>
            <left>-10</left>
            <width>144</width>
            <height>150</height>
            <texture colordiffuse="95FFFFFF">pointer.png</texture>
        </control>
        <control type="image" id="2">
            <description>Pointer Focus</description>
            <left>-10</left>
            <width>144</width>
            <texture colordiffuse="95FFFFFF" >pointer2.png</texture>
        </control>
        <control type="image" id="3">
            <description>Pointer Drag</description>
            <left>-10</left>
            <width>144</width>
            <texture colordiffuse="95FFFFFF">pointer3.png</texture>
        </control>
        <control type="image" id="4">
            <description>pointer_click</description>
            <left>-10</left>
            <width>144</width>
            <texture colordiffuse="95FFFFFF">pointer2.png</texture>
        </control>
    </controls>
</window>
