2020-06-10, 09:30
Hello, I would like to introduce my Addon for grabbing EPG data
Description:
This is an easy-to-use kodi addon which grabs epg data from various providers and creates a guide.xml from it.
Features:
Quick start Guide:
Provider List:
My Repository can be downloaded here : Takealug Addon Repo
Github : DeBaschdi
-Of course, the channels of the individual providers can be mixed, in the end everything always comes in a guide.xml. The addon can also be installed on one or more clients and automatically copies the guide.xml via smb to a tv server, or saves it for local connection. If the client is out of the grabbing time during the set request, the addon will do this for the next boot. The grabbing process usually takes no longer than 1 to 2 minutes.
-The configuration files from sunsettrack4 (easyepg) are compatible with the addon. This means that new mapping variables (EIT genre + Rytec Chid's) can be sent there as a pull request. This also automatically benefits easyepg (of course the addon too)
Description:
Features:
- High Speed Download + XML Creation (Multithreading Support for Linux)
- Channel Selector
- Enable / Disable EIT Genre Format
- Enable / Disable Rytec Channel Format
- Episodeformat onscreen / xmltv_ns
- Adjustable days for EPG Grabbing
- Build in Cron Feature
- Adjustable save location for the EPG, also over the network
- Write Guide directly in Tvheandend's xmltv.sock
- Special Feature : Rating Mapper (Push Age / Starrating , Country, Year Season/Episode on top of the Description)
Quick start Guide:
- Windows Only : Windows Defender add exclusion for realtimescan *.xml, *.json *.txt
- Kodi --> Settings(Expertview) -->Media -->General "Allow file renaming and deletion"
- Install addon.
- Select storage path for the guide.xml
- Activate provider.
- Select channels.
- Grab the epg manually (see if everything works)
- Activate automatic grabbing.
Provider List:
- -Magenta TV (DE)
- TV Spielfilm (DE)
- Swisscom (CH)
- Horizon (DE,AT,CH,NL,PL,IE,GB,SK,CZ,HU,RO)
- Zattoo (DE,CH,1und1TV,Quickline Mobil-TV,M-net TVplus,WALY.TV,Meine Welt unterwegs,BBV TV,VTX TV,myVision mobile TV,Glattvision+,SAK TV,Net TV,EWE TV App,Quantum TV,Salt TV,SWB TV App,eir TV)
Github : DeBaschdi
