Full Version: M3u file with VOD url. How to get movie information?
Hello there,
Is there any option to get movie information when you are using an m3u file that has movies' url?
Something similar as when you add a new video source and use an information provider as "Universal movie Scapper" to get all the movie information based on the name of the file.
For instance if my M3u file has this entry:
#EXTINF:-1,[REC] (2007) (Horror; Mystery; Thriller)
http://test:8880/movie/1234.mp4
I would like to be able to search on the "Universal movie Scapper" database all the information about movie "[REC] (2007) (Horror; Mystery; Thriller)".
My m3u file also has a Url behind, that I store in Google drive.
I did a temporary solution, create my one EPG data for these movies, but at the end this is not so accurate as is using "Universal movie Scapper" database or any other movie database that it's updated in real time.
I have read several forums about scraper, strm files and things like that, but at the end is such work that I prefer my own EPG data if there isn’t any other easiest option.
If it is not clear, please tell me.
If you use XMLTV data I think that supports an IMDB url.
For what I have read, XMLTV is the same thing that I did with my own EPG file with movies data. (I already did that).
What I want is that the data be download directly from add-on "Universal movie Scapper" or any other provider information add-on.
Thanks anyway.
(2020-06-15, 08:13)Iluso Wrote: [ -> ]For what I have read, XMLTV is the same thing that I did with my own EPG file with movies data. (I already did that).
Thanks anyway.
I am having the same question but a slightly different reason. I have a lot of home movies that i want to add descriptions to in a file and then when i go to the movies tab, be able to see descriptions of them. Like "Vegas-2020.mp4: Vegas 2020 - Family trip to Vegas in March 2020. Shows, Roller Coasters, Gambling, Weird Party". Then when I highlight it, i see the description. like what happens with IMDB on movies I have on my hard drive. With the SimpleIPTV add-on, I only get 1 EPG to add which works for the liveTV entries, but I want to get everything into a single EPG (Live TV, Movies, and Home Movies). How are you generating your EPG file if i may ask? Do i have to have <channel ...>...</channel> .... <programme ...> ...</programme> with channel listings at the top and program info at the bottom or can my epg have like channel, program, channel, program? Right now I am just writing a perl script to get the EPG, parsing out the TV information, then going to pull in and parse a list of home movie files and descriptions to attach to them. I think it should work, but since you are already creating an EPG yourself, I wanted to ask the master.
