(2020-06-13, 14:03)FoxADRIANO Wrote: [ -> ]nodgin,
you are awesome. In a flash you understood the problem. You are right. I was making an h.264 25p 10bit file and Shield TV couldn't read it. Now I have just made a h.265 25p 10bit file and the Shield TV reads it well.
Yes - 10-bit h.264 is not a widespread format and almost no hardware platform supports it with accelerated decode (There are a couple that do - but they aren't mainstream devices)
Quote:Anyway in MediaInfo I see 4:2:0 in the files and I don't understand the reason. I'm recording 25p 10bit 4:2:2 with my Lumix GH5.
The reason is that you are shooting 4:2:2, but DaVinci Resolve realises that you will want to export at 4:2:0 as a default (as no consumer platforms have 4:2:2 decoders - it's a broadcast/postproduction-only format)
You shoot 4:2:2 because it gives you higher quality recordings - better quality material to take into your grade, better quality if you re-frame a shot in an edit etc.
You export 4:2:0 because it's the format that players support (it's what all the main consumer video platforms use) Dropping to 4:2:0 at the end of the process is far less of a worry in quality terms than starting 4:2:0 (as the errors that are introduced by shooting 4:2:0 get worse the more you edit the content)
In your mind you have to separate the format you are shooting in and the format you are exporting in. They are formats doing two different jobs, and therefore you use different settings or formats for those two jobs.
Quote:Therefore are you telling me Shield TV should read 25p 10bit 4:2:0? I have even problem with 25p 10bit 4:2:0.
No. I'm not saying that the ONLY 10-bit format you should expect to use is 10-bit 4:2:0 h.265.
You just said you DIDN'T have a problem with p25 10-bit HEVC/h.265 an that the Shield reads it well? I'm assuming you are saying that h.264 10-bit is causing you problems? Well it will - it's not a supported format on almost any platform.
You can't use h.264 with 10-bit and expect it to play on any mainstream Kodi platform with hardware decode. You can't expect to play 4:2:2 on any mainstream Kodi platform with hardware decode.
Quote:I don't understand when you wrote I can export my timeline at p50, do you mean h.264 or h.265?
I didn't write that ? I said that the example source clip you gave me was p50, but I dropped it onto p25 timeline so I could export it at p25 from Resolve (i.e. my project settings were 25fps and I didn't change them when I put a 50fps clip onto the timeline)
Quote:I thought Shield TV was better, instead it has big limits on reading files. But OK.
Better than what? None of the consumer price point Kodi platforms would support 4:2:2 h.264 or h.265 decode, nor would they support h.264 10-bit (with the exception of a couple of less popular platforms based on RockChip)
'Big Limits'? It plays pretty much anything anyone would expect it to play?
You don't expect a $200 box to play camera rushes and edit masters that you'd play on a $3000 edit workstation.
