Full Version: xbox controller stopped working with kodi-20200612-3c5b7694-master-arm64-v8a.apk
Hello,
I've been using an alpha dev for the past 5-6 months and things are working fine. Today I wanted to test my luck and I installed the latest one (kodi-20200612-3c5b7694-master-arm64-v8a.apk), which unfortunately it caused my xbox controller to stop working.
Nothing on the xbox controller is working, even if I go set the keys via the key controller page, nothing is accepted. For example I click to set the "A" button, it says "Press A" with a count down timer, but the xbox controller input is not recognized, none of the keys do anything.
Anyone seen this issue before?
Thank you.
