Hello,
I experience some problem with the album titles that are shifted up as you can see on the
picture.
Kodi 18.7 Amber 3.2.23
(2020-06-14, 00:55)BlueScreenOfDeath Wrote: [ -> ]Hello,
I experience some problem with the album titles that are shifted up as you can see on the picture.
BlueScreenOfDeath, please update to a more recent version of Amber. You can install the Amber repo (
https://github.com/bartolomesoriano/repo...-1.0.1.zip)
And keep the skin updated from there. Current version is 3.2.92. Thanks.
Regards,
Bart
(2020-06-14, 15:03)bsoriano Wrote: [ -> ] (2020-06-14, 00:55)BlueScreenOfDeath Wrote: [ -> ]Hello,
@BlueScreenOfDeath, please update to a more recent version of Amber. You can install the Amber repo (https://github.com/bartolomesoriano/repo...-1.0.1.zip)
Regards,
Bart
Thanks, that worked.
But when I continued to play with the skin I found, that exactly the same problem exists if to choose "Small" subsetting for any "Panel" layout.
(2020-06-14, 22:49)BlueScreenOfDeath Wrote: [ -> ] (2020-06-14, 15:03)bsoriano Wrote: [ -> ] (2020-06-14, 00:55)BlueScreenOfDeath Wrote: [ -> ]Hello,
Regards,
Bart
BlueScreenOfDeath, thanks. I am aware and already fixed the issue. I will upload the changes to the Amber repo most likely tomorrow.
Regards,
Bart
BlueScreenOfDeath , please test Amber version 3.2.93. The issue is fixed on that version. It is already on the Amber repo. Thanks.
Regards,
Bart
(2020-06-18, 00:20)bsoriano Wrote: [ -> ]@BlueScreenOfDeath , please test Amber version 3.2.93. The issue is fixed on that version. It is already on the Amber repo. Thanks.
Regards,
Bart
Thank you, it looks very good now.
