It was no problem to play local files
But It was failed to play recordings file from remote location
I have opened 9981 9982 port for remote play (no problem live streaming)
Need to open more port?
(2020-06-14, 18:20)k3park Wrote: [ -> ]It was no problem to play local files
Is port forwarding enabled at the server location?
I used to do this routinely a few years ago (so I could watch UK TV when overseas). However I now use a VPN solution rather than port forwarding (I know this may not be ideal for streaming video but I've had reasonable success)
Beware - hackers will exploit open ports and TV Headend to attempt to install scripts that can be run (I've seen this happen) - so ensure your passwords are unlikely to be cracked.
Thank you for reply
I tried to connect with openvpn, But It still failed to stream recorded file from tvheadend recordings menu.
