Full Version: Matrix pvr addon after change to c++ interface
A user reported a problem updating pvr.nextpvr with the current nightly and I checked and the nightly he is running is the same git version as I am in development.
I checked another setup I have with an existing Windows version on Matrix and I found a similar problem.  There are no options to install the typical PVR addons via the main 3.2.3 addon repo  Is this a problem that is being fixed with the open PRs on binary addons? This is not clear to me.
What I see is my Addon27.db has blacklisted the two pvr addons I had installed and it shows just two PVR addons pvr.freebox and pvr.octonet from the kodi repo I don't have a database from before a ran the current nightly.
If I manually modify Addon27.db
delete from repo
where addonId = 'repository.xbmc.org'
things appear to be back to normal although the two pvr addons still show blacklisted.
Martin
I am seeing this issue as well.
Nothing in the repository except for "digital devices octopus NET client"
My Matrix DB had become corrupted, and I needed to re-install, and there was no NextPVR in the repo.
I thought it was just me, thanks for the info.
Good thing I had a backup. haha.
Is this the same issue...
2020-06-19 07:07:16.985 T:556      INFO <general>: Starting Kodi (19.0-ALPHA1 (18.9.701) Git:20200616-1eed8f06a9). Platform: Windows NT x86 64-bit
2020-06-19 07:07:16.985 T:556 INFO <general>: Using Release Kodi x64 build
2020-06-19 07:07:16.985 T:556 INFO <general>: Kodi compiled 2020-06-17 by MSVC 191627034 for Windows NT x86 64-bit version 10.0 (0x0A000006)
2020-06-19 07:07:16.985 T:556 INFO <general>: Running on Windows 10, kernel: Windows NT x86 64-bit version 10.0.18363
2020-06-19 07:08:16.563 T:556 DEBUG <general>: CAddonInstaller: installing 'pvr.nextpvr' version '5.0.3' from repository 'repository.xbmc.org'
2020-06-19 07:08:16.564 T:5772 DEBUG <general>: CAddonInstallJob[pvr.nextpvr]: requires kodi.binary.instance.pvr version 6.5.2 which is not available
2020-06-19 07:08:16.564 T:5772 ERROR <general>: CAddonInstallJob[pvr.nextpvr]: The dependency on kodi.binary.instance.pvr version 6.5.2 could not be satisfied.
Not really because addons.xml.gz did show 6.0.0 was the current version.  For that you might need to update the Kodi Add-on repo to 3.2.3
Edit:  6.0.1 is now the current version.
Martin
I tried the same "bad" Addons database with a recent nightly and it finds all the correct PVR clients now so the changes did seem to make the difference.
Martin
I posted too soon earlier I am still seeing errors finding NextPVR on Windows x86_64  nightlies It seems to be staying on 6.0.1 on the mirrors and it is possible the tag build is "stuck"
https://jenkins.kodi.tv/view/Addons/job/...view/tags/
6.0.2 builds cleanly since it was tagged and now yesterday's 6.0.3 isn't showing up either.  I am not sure what is missing,  any suggestions?
The value in addons28 is 6.0.1 on 64bit and 6.0.2 for 32bit.
Martin
I suspect Matrix updates have been dead since this PDB fail https://jenkins.kodi.tv/blue/organizatio.../pipeline/
Martin
I've left a message for someone to look at it @emveepee
Great thanks to both of you.  Hopefully that means that 6.03 will become available now too.
Martin
Yes ok 6.0.2 now shows up in x64 but I am not sure it is completely fixed.   6.0.3 still doesn't show up as a tag https://jenkins.kodi.tv/view/Addons/job/...view/tags/
Martin
Yes I saw that it was recompiled this afternoon and it shows up now if I delete addons28.db (or likely if I was patient on the update scheduled).  Thanks again.
Martin
