Full Version: compile xmbc in kheras VIM3
Hello,
   I try to compile xmbc into kheras VIM3, kernel 4.9.206.
My problem is often the EGL module.
  • When I compile with X11 plateform with
cmake -j10 .. -DCMAKE_INSTALL_PREFIX=/usr/local -DCORE_PLATFORM_NAME=x11 -DX11_RENDER_SYSTEM=gles
make
Scanning dependencies of target utils
[ 70%] Building CXX object build/utils/CMakeFiles/utils.dir/EGLUtils.cpp.o
/home/khadas/xbmc/xbmc/utils/EGLUtils.cpp:102:5: error: ‘EGL_DEBUG_MSG_CRITICAL_KHR’ was not declared in this scope
   X(EGL_DEBUG_MSG_CRITICAL_KHR),
/home/khadas/xbmc/xbmc/utils/EGLUtils.cpp:38:31: note: in definition of macro ‘X’
 #define X(VAL) std::make_pair(VAL, #VAL)
/home/khadas/xbmc/xbmc/utils/EGLUtils.cpp:102:5: note: suggested alternative: ‘EGL_BITMAP_PITCH_KHR’
the variable is not present EGL_BITMAP_PITCH_KHR into EGL/eglext.h ( package linux-gpu-mali-fbdev )
  • When gbm
cmake -j10 ..  -DGBM_RENDER_SYSTEM=gles       -DCORE_PLATFORM_NAME=gbm
make
In file included from /home/khadas/xbmc/xbmc/windowing/gbm/DRMUtils.h:11:0,
                 from /home/khadas/xbmc/xbmc/windowing/gbm/WinSystemGbm.h:11,
                 from /home/khadas/xbmc/xbmc/utils/DumbBufferObject.cpp:14:
/home/khadas/xbmc/xbmc/windowing/gbm/GBMUtils.h:11:10: fatal error: gbm.h: No such file or directory
 #include <gbm.h>
compilation terminated.
build/utils/CMakeFiles/utils.dir/build.make:2006: recipe for target 'build/utils/CMakeFiles/utils.dir/DumbBufferObject.cpp.o' failed
make[2]: *** [build/utils/CMakeFiles/utils.dir/DumbBufferObject.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
[ 85%] Built target dvdinputstreams
gbm.h is not present beacuse linux-gpu-mali-gbm replace linux-gpu-mali-fbdev.
  • with configuration rbpi
cmake -j10 ..  -DGBM_RENDER_SYSTEM=gles       -DCORE_PLATFORM_NAME=rbpi
CMake Error at /usr/share/cmake-3.10/Modules/FindPackageHandleStandardArgs.cmake:137 (message):
  Could NOT find OpenGLES (missing: OPENGLES_gl_LIBRARY)
Call Stack (most recent call first):
  /usr/share/cmake-3.10/Modules/FindPackageHandleStandardArgs.cmake:378 (_FPHSA_FAILURE_MESSAGE)
  cmake/modules/FindOpenGLES.cmake:37 (find_package_handle_standard_args)
  cmake/scripts/common/Macros.cmake:346 (find_package)
  cmake/scripts/common/Macros.cmake:360 (find_package_with_ver)
  CMakeLists.txt:173 (core_require_dep)
How can your xbmc on khadas compile?
Ask kheras or whatever company is making these boards support to provide proper mali userspace stuff with gbm.
