Full Version: Compile on RPi4 Error
Hello,
I'm trying to compile on a RPi4 and I keep getting a MakeFile:141 all error. The post I used as a guide is this: https://forum.kodi.tv/showthread.php?tid=351221 I've posted the Error Log and Output Log below.
Error Log- https://pastebin.com/NtVABpRJ
Output Log- https://pastebin.com/cH3LwdHe
Any help is appreciated.
Cross/double posting is frowned upon on these forums.
As you've used the guide in the post you've linked the best place to continue is that post.
The logs you've linked are useless btw, these are cmake internal logs, won't help in this case.
Please provide the exact errors you are getting on your screen (the best place to do it is the guide thread)
Which logs should I post then? The error I am seeing is [MakeFile:141 all] Error 2
The whole output you see on the console, there is no log.
Please use the other thread, I will not provide further answers in this one.
