2020-06-28, 12:39
Hello,
I'm running Kodi 18.7 on two Shields, one is the 2015 Pro and the other is the 2019 Pro. I use a shared database for the library, running MariaDB 10.5.4 in a docker container (the official docker image - https://hub.docker.com/_/mariadb). The videos in the library reside on a FreeNAS server and are shared via SMB.
I had no issues until recently, I believe it was a recent update to MariaDB. Now on both Shields, the library only shows 0's instead of names for both movies and TV shows, however the resume points and watched statuses are preserved. When I try playing anything, Kodi acts as if it can't find the files (see screenshots below)
A debug log: https://paste.kodi.tv/kagudatuce.kodi
And here are the screenshots:
https://imgur.com/a/JGWJfxo
I'd like to mention that the database and SMB shares are working, and I verified this by trying with Kodi on a Windows PC, which seems to work just fine. Also, I can browse the shares with PC's running Windows and Linux, and I can also connect to the database using normal Windows/Linux clients.
