From the startup of kodi here's the last part of the log file showing the resolutions. Note the bold line, that's the resolution I would like kodi to use...
Help?
2020-07-02 14:20:21.620 T:2972556384 NOTICE: Raspberry PI firmware version: Jun 1 2020 13:23:40
Copyright © 2012 Broadcom
version 6379679d1ec6a8c746d7e77e015f5b56b939976f (clean) (release) (start)
2020-07-02 14:20:21.620 T:2972556384 NOTICE: ARM mem: 948MB GPU mem: 76MB MPG2:0 WVC1:0
2020-07-02 14:20:21.620 T:2972556384 NOTICE: Config:
arm_freq=1500
audio_pwm_mode=514
config_hdmi_boost=5
core_freq=500
core_freq_min=200
disable_commandline_tags=2
disable_l2cache=1
disable_overscan=1
display_hdmi_rotate=-1
display_lcd_rotate=-1
enable_gic=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=500
gpu_freq_min=250
hdmi_channel_map=8
init_uart_clock=0x2dc6c00
lcd_framerate=60
mask_gpu_interrupt0=1024
mask_gpu_interrupt1=0x10000
max_framebuffers=2
over_voltage_avs=-36250
pause_burst_frames=1
program_serial_random=1
total_mem=4096
hdmi_force_cec_address:0=65535
hdmi_force_cec_address:1=65535
hdmi_pixel_freq_limit:0=0x11e1a300
hdmi_pixel_freq_limit:1=0x11e1a300
device_tree=-
overlay_prefix=overlays/
hdmi_cvt:0=
hdmi_cvt:1=
hdmi_edid_filename:0=
hdmi_edid_filename:1=
hdmi_timings:0=
hdmi_timings:1=
2020-07-02 14:20:22.244 T:2972556384 WARNING: CDRMUtils::FindPlane - could not find plane
2020-07-02 14:20:22.244 T:2972556384 WARNING: CDRMUtils::InitDrm - failed to set drm master, will try to authorize instead: Permission denied
2020-07-02 14:20:22.245 T:2972556384 NOTICE: CDRMUtils::InitDrm - successfully authorized drm magic
2020-07-02 14:20:23.141 T:2972556384 NOTICE: Found resolution 1366x768 with 1366x768 @ 60.000000 Hz
2020-07-02 14:20:23.141 T:2972556384 NOTICE: Found resolution 1920x1080 with 1920x1080 @ 60.000000 Hz
2020-07-02 14:20:23.141 T:2972556384 NOTICE: Found resolution 1920x1080 with 1920x1080 @ 59.940063 Hz
2020-07-02 14:20:23.141 T:2972556384 NOTICE: Found resolution 1920x1080 with 1920x1080 @ 24.000000 Hz
2020-07-02 14:20:23.141 T:2972556384 NOTICE: Found resolution 1920x1080 with 1920x1080 @ 23.976025 Hz
2020-07-02 14:20:23.141 T:2972556384 NOTICE: Found resolution 1360x768 with 1360x768 @ 60.000000 Hz
2020-07-02 14:20:23.141 T:2972556384 NOTICE: Found resolution 1280x720 with 1280x720 @ 60.000000 Hz
2020-07-02 14:20:23.141 T:2972556384 NOTICE: Found resolution 1280x720 with 1280x720 @ 59.940063 Hz
2020-07-02 14:20:23.141 T:2972556384 NOTICE: Found resolution 1024x768 with 1024x768 @ 75.000000 Hz
2020-07-02 14:20:23.141 T:2972556384 NOTICE: Found resolution 1024x768 with 1024x768 @ 70.000000 Hz
2020-07-02 14:20:23.142 T:2972556384 NOTICE: Found resolution 1024x768 with 1024x768 @ 60.000000 Hz
2020-07-02 14:20:23.142 T:2972556384 NOTICE: Found resolution 800x600 with 800x600 @ 75.000000 Hz
2020-07-02 14:20:23.142 T:2972556384 NOTICE: Found resolution 800x600 with 800x600 @ 72.000000 Hz
2020-07-02 14:20:23.142 T:2972556384 NOTICE: Found resolution 800x600 with 800x600 @ 60.000000 Hz
2020-07-02 14:20:23.142 T:2972556384 NOTICE: Found resolution 720x480 with 720x480 @ 59.940063 Hz
2020-07-02 14:20:23.142 T:2972556384 NOTICE: Found resolution 720x480 with 720x480 @ 60.000000 Hz
2020-07-02 14:20:23.142 T:2972556384 NOTICE: Found resolution 640x480 with 640x480 @ 75.000000 Hz
2020-07-02 14:20:23.142 T:2972556384 NOTICE: Found resolution 640x480 with 640x480 @ 60.000000 Hz
2020-07-02 14:20:23.142 T:2972556384 NOTICE: Previous line repeats 1 times.
2020-07-02 14:20:23.142 T:2972556384 NOTICE: Found resolution 720x400 with 720x400 @ 70.000000 Hz
2020-07-02 14:20:23.144 T:2972556384 NOTICE: EGL_VERSION = 1.4
2020-07-02 14:20:23.144 T:2972556384 NOTICE: EGL_VENDOR = Mesa Project
2020-07-02 14:20:23.144 T:2972556384 NOTICE: EGL_EXTENSIONS = EGL_ANDROID_blob_cache EGL_EXT_buffer_age EGL_EXT_image_dma_buf_import EGL_EXT_image_dma_buf_
import_modifiers EGL_KHR_cl_event2 EGL_KHR_config_attribs EGL_KHR_create_context EGL_KHR_create_context_no_error EGL_KHR_fence_sync EGL_KHR_get_all_proc_add
resses EGL_KHR_gl_colorspace EGL_KHR_gl_renderbuffer_image EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_3D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_
image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_no_config_context EGL_KHR_reusable_sync EGL_KHR_surfaceless_context EGL_EXT_pixel_format_float EGL_KHR
_wait_sync EGL_MESA_configless_context EGL_MESA_drm_image EGL_MESA_image_dma_buf_export EGL_MESA_query_driver EGL_WL_bind_wayland_display
2020-07-02 14:20:23.144 T:2972556384 NOTICE: EGL_CLIENT_EXTENSIONS = EGL_EXT_device_base EGL_EXT_device_enumeration EGL_EXT_device_query EGL_EXT_platform_b
ase EGL_KHR_client_get_all_proc_addresses EGL_EXT_client_extensions EGL_KHR_debug EGL_EXT_platform_wayland EGL_EXT_platform_x11 EGL_MESA_platform_gbm EGL_ME
SA_platform_surfaceless EGL_EXT_platform_device
2020-07-02 14:20:23.147 T:2972556384 NOTICE: Checking resolution 16
2020-07-02 14:20:23.294 T:2972556384 WARNING: CGBMUtils:
estroySurface - surface already destroyed
2020-07-02 14:20:23.335 T:2972556384 NOTICE: GL_VENDOR = Broadcom
2020-07-02 14:20:23.335 T:2972556384 NOTICE: GL_RENDERER = V3D 4.2
2020-07-02 14:20:23.335 T:2972556384 NOTICE: GL_VERSION = OpenGL ES 3.1 Mesa 19.3.2
2020-07-02 14:20:23.335 T:2972556384 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.10
2020-07-02 14:20:23.336 T:2972556384 NOTICE: GL_EXTENSIONS = GL_EXT_blend_minmax GL_EXT_multi_draw_arrays GL_EXT_texture_format_BGRA8888 GL_OES_compressed_
ETC1_RGB8_texture GL_OES_depth24 GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_mapbuffer GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_st
encil8 GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_half_float GL_EXT
_texture_sRGB_decode GL_OES_EGL_image GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_type_2_10_10_10_REV GL_OES_get_program_binary GL_APPLE
_texture_max_level GL_EXT_discard_framebuffer GL_EXT_read_format_bgra GL_EXT_frag_depth GL_NV_fbo_color_attachments GL_OES_EGL_image_external GL_OES_EGL_syn
c GL_OES_vertex_array_object GL_EXT_occlusion_query_boolean GL_EXT_texture_rg GL_EXT_unpack_subimage GL_NV_draw_buffers GL_NV_read_buffer GL_NV_read_depth G
L_NV_read_depth_stencil GL_NV_read_stencil GL_EXT_draw_buffers GL_EXT_map_buffer_range GL_KHR_debug GL_KHR_texture_compression_astc_ldr GL_OES_depth_texture
_cube_map GL_OES_required_internalformat GL_OES_surfaceless_context GL_EXT_color_buffer_float GL_EXT_sRGB_write_control GL_EXT_separate_shader_objects GL_EX
T_shader_implicit_conversions GL_EXT_shader_integer_mix GL_EXT_base_instance GL_EXT_compressed_ETC1_RGB8_sub_texture GL_EXT_draw_elements_base_vertex GL_EXT
_primitive_bounding_box GL_EXT_shader_io_blocks GL_EXT_texture_border_clamp GL_EXT_texture_norm16 GL_KHR_context_flush_control GL_NV_image_formats GL_OES_dr
aw_elements_base_vertex GL_OES_primitive_bounding_box GL_OES_shader_io_blocks GL_OES_texture_border_clamp GL_OES_texture_stencil8 GL_OES_texture_storage_mul
tisample_2d_array GL_EXT_buffer_storage GL_EXT_float_blend GL_KHR_no_error GL_KHR_texture_compression_astc_sliced_3d GL_OES_EGL_image_external_essl3 GL_OES_
shader_image_atomic GL_MESA_shader_integer_functions GL_KHR_parallel_shader_compile GL_MESA_framebuffer_flip_y GL_EXT_texture_query_lod
2020-07-02 14:20:23.845 T:2764468432 NOTICE: Running database version Addons27
2020-07-02 14:20:23.846 T:2764468432 NOTICE: Running database version ViewModes6
2020-07-02 14:20:23.846 T:2764468432 NOTICE: Running database version Textures13
2020-07-02 14:20:23.849 T:2764468432 NOTICE: Running database version MyMusic72
2020-07-02 14:20:23.853 T:2764468432 NOTICE: Running database version MyVideos116
2020-07-02 14:20:23.854 T:2764468432 NOTICE: Running database version TV32
2020-07-02 14:20:23.855 T:2764468432 NOTICE: Running database version Epg12
2020-07-02 14:20:23.872 T:2972556384 NOTICE: start dvd mediatype detection
2020-07-02 14:20:23.907 T:2972556384 NOTICE: load skin from: /usr/share/kodi/addons/skin.estuary (version: 2.0.27)
2020-07-02 14:20:24.165 T:2972556384 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
2020-07-02 14:20:24.197 T:2972556384 NOTICE: Register - new keyboard device registered on application->keyboard: Keyboard (0000:0000)
2020-07-02 14:20:24.198 T:2972556384 NOTICE: Register - new mouse device registered on application->mouse: Mouse (0000:0000)
2020-07-02 14:20:24.200 T:2972556384 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
2020-07-02 14:20:24.200 T:2972556384 NOTICE: Loaded playercorefactory configuration
2020-07-02 14:20:24.200 T:2972556384 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
2020-07-02 14:20:24.200 T:2972556384 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
2020-07-02 14:20:24.208 T:2972556384 NOTICE: initialize done
2020-07-02 14:20:24.208 T:2972556384 NOTICE: Running the application...
2020-07-02 14:20:24.213 T:2972556384 NOTICE: starting zeroconf publishing
2020-07-02 14:20:24.213 T:2666750160 NOTICE: ES: Starting UDP Event server on port 9777
2020-07-02 14:20:24.213 T:2666750160 NOTICE: UDP: Listening on port 9777 (ipv6 : false)
2020-07-02 14:20:24.225 T:2972556384 NOTICE: VideoPlayer::OpenFile: /var/run/lirc/lircd
2020-07-02 14:20:24.242 T:2631184592 NOTICE: Creating InputStream
2020-07-02 14:20:24.242 T:2631184592 ERROR: CVideoPlayer::OpenInputStream - error opening [/var/run/lirc/lircd]
2020-07-02 14:20:24.242 T:2631184592 NOTICE: CVideoPlayer::OnExit()
2020-07-02 14:20:24.431 T:2717368528 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
2020-07-02 14:20:24.659 T:2972556384 NOTICE: CVideoPlayer::CloseFile()
2020-07-02 14:20:24.659 T:2972556384 NOTICE: VideoPlayer: waiting for threads to exit
2020-07-02 14:20:24.659 T:2972556384 NOTICE: VideoPlayer: finished waiting
pi@raspberrypi:~/.kodi/temp $
