Dear all, I want to buy a TV box with the following Specifications:
1- It can passtrough to my soundbar Lossless Truehd and Master audio
2- playsback H 265
3- supports 4k HDR
4- it has sattelite antenna for sattelite channels
Is there any website with filter search?
Suggestion - do a Google Search for "CoreELEC DVB-S"...
and a bunch of links will popup for DIY solutions mainly involving the MECOOL KIII Pro - which would likely be the cheapest DIY solution.. like...
Which DVB-S2 box for CoreELEC (click) ?
For USB DVB-S2 Tuners....
Which cheap and good usb DVB-S2 tuner to buy?
Otherwise for easier Plug n Play you are paying $$$ for Sat-IP based tuners such as the Telestar Digibit Twin Sat to IP HD Digital Receiver Router.
The advantage with - verified working - USB Tuners or Sat-IP is you can use them with any modern AMLogic S905X2 / S905X3 / S922X -->> 4K HDR & HD audio CoreELEC Kodi device, like the ones suggested in....
START HERE - Pick the Right Kodi Box (click)
Yes - I'd definitely recommend going down the SAT>IP route these days. (USB DVB-S2 tuner support can still sometimes be a bit hit or miss, particularly when manufacturers change chipsets in models without updating their model number...). If you have a Quad/Quattro LNB then the Telestar Digibit 4 Tuner box is a great option - and you can also run third party firmware on it to add extra functionality (including Unicable II support - which I'm not sure the basic firmware has. Unicable II allows you to run a single LNB cable to the box and still have full 4 tuner support across all H/V/Hi/Lo bands)
