About
Binge is Australia’s newest streaming service, where nothing gets on your screen unless it’s binge-worthy, award-worthy, share-worthy or all-time-favourite-worthy.
Packed with the world’s best TV shows and heaps of movies for whatever mood you’re in. Plus comedy, crime, reality, documentaries, sci-fi and more.
Info & Install Instructions
https://www.matthuisman.nz/2020/07/binge-kodi-add-on.html
(2020-07-06, 10:55)matthuisman Wrote: [ -> ]
About
Hey mate, thanks for your work on this add on. I am having some issues with Binge that I was hoping you could help with. The video freezes when I am in the middle of watching something and does not do anything. I have tried different versions of kodi, tested network speed which is fine, cleared video cache and many other settings.
I hope you can get back to me with any advice, it would be greatly appreciated. Thanks
bigbird777
I'd need more info (what content, how long, always at same spot?) and a debug log.
(2021-03-22, 03:44)matthuisman Wrote: [ -> ]@bigbird777
hello thanks for the binge add on, I am having the same issue as the person.
kodi v19 windows 10, issue is running widevine 4.10.2202.0 Bing required the update upon doing so Binge video while playing around two the five minutes in will drop out and you end back at the Binge selection screen. i dont see errors in the log its like a buffer drop out but not.
so installed a old widevine and binge did not prompted a update running 4.10.1582.2 there are no issues videos play fine in Binge however 9au etc won't play without the latest version causing a massive headache.
Can not find anything in google to this issue.
I have tried everything to no avail, only work around is constantly re installing and rolling back widevine when using Binge.
i couldn't reproduce the same issue with latest WV but i've tried all DRM content (9au etc) still plays fine using 4.10.1582.2 (and even the older 4.10.1440.19)
(2021-03-28, 23:34)matthuisman Wrote: [ -> ]i couldn't reproduce the same issue with latest WV but i've tried all DRM content (9au etc) still plays fine using 4.10.1582.2 (and even the older 4.10.1440.19)
I did a clean install of kodi with just Binge nothing else and widevine 4.10.2209.0 and it still drops out, roll back to 4.10.152.2 is the only way it works, Aussie add-ons 9 needs 4.10.2209.0 to play streams, sylguys 9 works with 4.10.152.2 fine so rebuilt with syluys channels where I could so binge can work since its only stable on WV 4.10.152.2 .
not sure if system can play a part settings as Kodi set to DXVA DXVA2 system is running AMD 3700x,64gig ram, gtx1070.
Oh, I only tested using slyguy 9now addon. That's actually by me as well. Slyguy just takes care of repo. They both will be using the same content so very strange one works and other doesn't. I think the Aussie addons even uses the same DRM location as me if I recall.
I may rollback the DRM then
Id love to see 10plus, ABC and SBS all under slyguys if possible even if logins needed with my accounts to each, I fear conflict needing others add-ins, its certainly more likely there is some type of conflict especially since my tests showed 7 and 9 to conflict from other repos. Be great to have a single source.
Binge is odd with the clean install must be something with Drivers maybe.
hope the other guy see the reply's and can confirm if the same works for him.
I appreciate you replying that the work you put into this, quality through Browser is so bad in comparison to through Kodi with your add-in.
matthuisman nothing on binge is playing, tries to load then just returns to the menu
i have confirmation it's fixed and have
Both binge and slyguy common need to be latest
personally tested with both Kodi 18 & 19
please make sure you've fully updated. then reboot kodi and try again
if still not working - you'll need to get me a debug log
its fully down sadly happened today on windows ten
ERROR <general>: XFILE::CDirectory::GetDirectory - Error getting plugin://slyguy.binge/
2021-04-15 21:55:27.295 T:4380 ERROR <general>: CGUIMediaWindow::GetDirectory(plugin://slyguy.binge/) failed
only errors i can see
(2021-04-15, 16:00)Silent Knight Wrote: [ -> ]its fully down sadly happened today on windows ten
ok odd slyguy sheared updated can see menu now but nothing will play
2021-04-15 22:33:31.549 T:13176 INFO <general>: CPythonInvoker(36, C:\Users\The Box\AppData\Roaming\Kodi\addons\slyguy.binge\default.py): script successfully run
2021-04-15 22:33:31.549 T:4696 ERROR <general>: CCurlFile::FillBuffer - Failed: Server returned nothing (no headers, no data)(52)
2021-04-15 22:33:31.549 T:4696 ERROR <general>: CCurlFile::Open failed with code 0 for
http://127.0.0.1:52103/plugin://slyguy.b...se_request:
2021-04-15 22:33:31.549 T:4696 ERROR <general>: AddOnLog: inputstream.adaptive: License server returned failure
2021-04-15 22:33:31.549 T:4696 ERROR <general>: AddOnLog: inputstream.adaptive: License update not successful (no keys)
2021-04-15 22:33:31.549 T:4696 ERROR <general>: AddOnLog: inputstream.adaptive: Initialize failed (SingleSampleDecrypter)
2021-04-15 22:33:31.584 T:4696 ERROR <general>: CVideoPlayer::OpenInputStream - error opening [plugin://slyguy.binge/?_=play&_play=1&id=31348&play_type=0&start_from=0]
Please post link to full debug log
Binge version should be at least: 0.2.3
Slyguy common version should be at least: 0.25.8
