Hi everybody,
I have an M3U file which works under VLC (or other M3U player) but not under Kodi with the IPTV SINGLE CLIENT addon. My provider has certainly changed something about the video stream. But I don't know what. I searched everywhere but I can't find an answer.
Thanks for your help.
Marc
(2020-07-07, 09:19)Marcguyver Wrote: [ -> ]Hi everybody,
Marc
A correct way to put that is your provider blocks kodi, nothing wrong with kodi/pvr client.
Change the http user-agent string, in the latest versions you can set this in the options of iptv simple client
Thx for your answer. But i dont know How to change that, can you explain me ? 😁
(2020-07-07, 23:12)Marcguyver Wrote: [ -> ]Thx for your answer. But i dont know How to change that, can you explain me ? 😁
Add the user agent (google popular http user agents) in the pvr simple client settings
(2020-07-08, 00:03)ohhwee Wrote: [ -> ] (2020-07-07, 23:12)Marcguyver Wrote: [ -> ]Thx for your answer. But i dont know How to change that, can you explain me ? 😁
Which is the correct format for this? How can I put this on the apropiate addon settings?. Can you put an example? Thanks in advance
(2020-07-08, 08:49)pacobar Wrote: [ -> ] (2020-07-08, 00:03)ohhwee Wrote: [ -> ] (2020-07-07, 23:12)Marcguyver Wrote: [ -> ]Thx for your answer. But i dont know How to change that, can you explain me ? 😁
You have the same problem?
I try something but it doesnt work -_-
Hi, i try a lot of thing but nothing change. Can you give me a exemple please ?
thanks a lot
