I had this problem where i cant seem to open any addon after downloading and installing it even kodi log file uploader... i have been reinstalling it did a fresh install too cant seem to fix anything...
I have added my log file below so y'all can check it out and see if you can fix this issue.
https://paste.kodi.tv/opixulucut.kodi
The diggz repository
(2020-07-07, 18:14)rick3kap Wrote: [ -> ]I had this problem where i cant seem to open any addon after downloading and installing it even kodi log file uploader
The only references I can find when googling the 'Diggz' repository which you installed, are links to a Xenon build, which as per our
forum rules (wiki) will not get you any support on this forum because of its video piracy affiliation.
To be clear, any hint of an installation of a 'wizard' or 'build' on your Kodi device, or mentioning it on our forum, will halt our help to you. As simple as that. It's nothing personal, just consider it our 'company policy'.
If that all is not the case, then please enlighten us.
