Full Version: TVHeadend works via wifi but not ethernet
I have live tv working on Kodi 18.7 on the Android Sony 900f via wifi but want to switch to ethernet due to a lot of loss connections.
When I connect the tv to ethernet, I can see I have access to the internet for other apps but when I load Kodi it will not connect to the TVHeadend server.  Does anybody have any idea why it works via wifi but not ethernet?
I have other HTSP set up via ethernet and they work fine it's just the Sony 900f which will not work via ethernet.
Below is the log from Kodi:
2020-07-14 17:05:13.729 T:28046  NOTICE: Running the application...
2020-07-14 17:05:13.752 T:28046  NOTICE: starting zeroconf publishing
2020-07-14 17:05:13.753 T:28089  NOTICE: ES: Starting UDP Event server on port 9777
2020-07-14 17:05:13.753 T:28089  NOTICE: UDP: Listening on port 9777 (ipv6 : false)
2020-07-14 17:05:23.732 T:28086   ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - unable to connect to 192.168.2.109:9982
2020-07-14 17:05:38.634 T:28029   ERROR: Previous line repeats 1 times.
2020-07-14 17:05:38.634 T:28029  NOTICE: UnregisterRemovedDevices - device removed from joystick/android/inputdevice/30: SONY TV RC MIC 001 (054C:0BE8)
2020-07-14 17:05:44.752 T:28086   ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - unable to connect to 192.168.2.109:9982
2020-07-14 17:12:13.060 T:28062   ERROR: Previous line repeats 20 times.
2020-07-14 17:12:13.060 T:28062  NOTICE: Trying to open: samplerate: 44100, channelMask: 12, encoding: 4
2020-07-14 17:12:13.091 T:28062  NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 44100 format: AE_FMT_FLOAT (AE) method: PCM stream-type: PCM-STREAM min_buffer_size: 60416 m_frames: 3776 m_frameSize: 8 channels: 2
2020-07-14 17:12:13.359 T:28029 WARNING: CAndroidJoystickState: ignoring unknown axis 32 on input device "SONY TV RC MIC 001" with ID 31
2020-07-14 17:12:13.547 T:28029  NOTICE: Register - new joystick device registered on android->android/inputdevice/31: SONY TV RC MIC 001 (054C:0BE8)
2020-07-14 17:12:15.436 T:28046  NOTICE: Stopping player
2020-07-14 17:12:15.437 T:28046  NOTICE: Storing total System Uptime
2020-07-14 17:12:15.437 T:28046  NOTICE: Saving settings
2020-07-14 17:12:15.449 T:28046  NOTICE: Saving skin settings
2020-07-14 17:12:15.453 T:28046  NOTICE: Stopping all
2020-07-14 17:12:15.455 T:28046  NOTICE: ES: Stopping event server
2020-07-14 17:12:15.457 T:28046  NOTICE: stopping zeroconf publishing
2020-07-14 17:12:16.146 T:28089  NOTICE: ES: UDP Event server stopped
2020-07-14 17:12:16.334 T:28046  NOTICE: Application stopped
2020-07-14 17:12:16.462 T:28086   ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - unable to connect to 192.168.2.109:9982
2020-07-14 17:12:16.535 T:28046  NOTICE: XBApplicationEx: destroying...
2020-07-14 17:12:26.493 T:28046  NOTICE: unload skin
2020-07-14 17:12:26.537 T:28046  NOTICE: CWinSystemAndroid:Big GrinestroyWindow
2020-07-14 17:12:26.560 T:28046  NOTICE: unload sections
2020-07-14 17:12:26.581 T:28046  NOTICE: CWinSystemAndroid:Big GrinestroyWindowSystem
2020-07-14 17:12:26.613 T:28046  NOTICE: XBApplicationEx: application stopped!
When I look at the log on the router I can see something was sent to the tvheadend server but nothing comes out.
Thanks in advance for any assistance.
This is just a shot in the dark, but in the Tvheadend web configuration go to Configuration|Users|Access Entries and make sure that the IP address of your Kodi box is among the allowed networks for the hts user (or whatever username you use with Kodi).  It may be only configured to accept the IP range for your wireless network but not your wired one.
(2020-07-15, 20:27)oldtvwatcher Wrote: [ -> ]This is just a shot in the dark, but in the Tvheadend web configuration go to Configuration|Users|Access Entries and make sure that the IP address of your Kodi box is among the allowed networks for the hts user (or whatever username you use with Kodi).  It may be only configured to accept the IP range for your wireless network but not your wired one.
Thanks for the response, but I currently have 0.0.0.0/0,::/0 in the user account.  Let me know if I'm incorrect but I thought that basically allows anything access as long as the username and password are correct.
I ended up moving the TVheadend server to the same room as the sony tv which gave it access.  I'm pretty sure the Fios router is blocking it as I see messages in the firewall log as ethernet 1 blocked which the server was hooked in to and I could not figure out a way to unblock it.
