Full Version: Display EPG for all channels at once
I just setup a myth-backend on a different computer and I have Kodi on a Raspberry PI 3. I installed mythtv PVR (I assume mythbox is not longer an option). When watching a channel I hit the EPG and it shows all the shows for the day. From the channels listing/selector, I can right mouse click and see all the shows for that channel for the day. Is there a way to popup the complete EPG that shows all the shows for every channel similar to the way the regular mythtv frontend does it?
Do you mean the E key for the EPG?
Martin
(2020-07-16, 05:39)emveepee Wrote: [ -> ]Do you mean the E key for the EPG?
Martin
Yes, thank you.
(2020-07-16, 19:00)stuckinthehome Wrote: [ -> ]
Martin
Yes, thank you.
Would anyone know how to map this to a key on my remote? I downloaded the keymap editor and went under PVR and assigned a button to record but it doesn't work as it takes me to the channel display screen.
