2020-07-17, 21:03
Hello,
does anyone have any idea why all other scalers than bilinear in Video Scaling Method are not working?
kodi 18.7
ubuntu 18.04
kodi 18.7
ubuntu 18.04
2020-07-13 12:32:19.376 T:140296047700096 NOTICE: Mixer feature: VDP_VIDEO_MIXER_FEATURE_NOISE_REDUCTION
2020-07-13 12:32:19.376 T:140296047700096 NOTICE: Mixer feature: VDP_VIDEO_MIXER_FEATURE_SHARPNESS
2020-07-13 12:32:19.376 T:140296047700096 NOTICE: Mixer feature: VDP_VIDEO_MIXER_FEATURE_DEINTERLACE_TEMPORAL
2020-07-13 12:32:19.376 T:140296047700096 NOTICE: Mixer feature: VDP_VIDEO_MIXER_FEATURE_DEINTERLACE_TEMPORAL_SPATIAL
2020-07-13 12:32:19.376 T:140296047700096 NOTICE: Mixer feature: VDP_VIDEO_MIXER_FEATURE_INVERSE_TELECINE
2020-07-13 12:32:19.376 T:140296047700096 NOTICE: Mixer feature: VDP_VIDEO_MIXER_FEATURE_HIGH_QUALITY_SCALING_L1
2020-07-13 12:32:19.376 T:140296047700096 NOTICE: VDPAU::Close - closing decoder context
2020-07-13 12:32:19.379 T:140296047700096 DEBUG: GLX_EXTENSIONS: GLX_EXT_visual_info GLX_EXT_visual_rating GLX_EXT_import_context GLX_SGIX_fbconfig GLX_SGIX_pbuffer GLX_SGI_video_sync GLX_SGI_swap_control GLX_EXT_swap_control GLX_EXT_swap_control_tear GLX_EXT_texture_from_pixmap GLX_EXT_buffer_age GLX_ARB_create_context GLX_ARB_create_context_profile GLX_EXT_create_context_es_profile GLX_EXT_create_context_es2_profile GLX_ARB_create_context_no_error GLX_ARB_create_context_robustness GLX_NV_delay_before_swap GLX_EXT_stereo_tree GLX_ARB_context_flush_control GLX_NV_robustness_video_memory_purge GLX_NV_multigpu_context GLX_ARB_multisample GLX_NV_float_buffer GLX_ARB_fbconfig_float GLX_EXT_framebuffer_sRGB GLX_NV_multisample_coverage GLX_NV_copy_image GLX_ARB_get_proc_address
2020-07-13 12:32:19.379 T:140296047700096 NOTICE: GL_VENDOR = NVIDIA Corporation
2020-07-13 12:32:19.379 T:140296047700096 NOTICE: GL_RENDERER = GeForce GT 730/PCIe/SSE2
2020-07-13 12:32:19.379 T:140296047700096 NOTICE: GL_VERSION = 4.6.0 NVIDIA 440.100
2020-07-13 12:32:19.379 T:140296047700096 NOTICE: GL_SHADING_LANGUAGE_VERSION = 4.60 NVIDIA
2020-07-13 12:32:19.379 T:140296047700096 NOTICE: GL_GPU_MEMORY_INFO_TOTAL_AVAILABLE_MEMORY_NVX = 2097152
2020-07-13 12:32:19.379 T:140296047700096 NOTICE: GL_GPU_MEMORY_INFO_DEDICATED_VIDMEM_NVX = 2097152
2020-07-13 12:32:19.379 T:140296047700096 NOTICE: GL_EXTENSIONS = GL_AMD_multi_draw_indirect GL_AMD_seamless_cubemap_per_texture GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_bindless_texture GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_compute_shader GL_ARB_compute_variable_group_size GL_ARB_conditional_render_inverted GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_derivative_control GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_indirect GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_ES3_1_compatibility GL_ARB_ES3_2_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_gl_spirv GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_gpu_shader_int64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_indirect_parameters GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_parallel_shader_compile GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_polygon_offset_clamp GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_query_buffer_object GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counter_ops GL_ARB_shader_atomic_counters GL_ARB_shader_ballot GL_ARB_shader_bit_encoding GL_ARB_shader_clock GL_ARB_shader_draw_parameters GL_ARB_shader_group_vote GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_image_samples GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_sparse_buffer GL_ARB_sparse_texture GL_ARB_spirv_extensions GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_barrier GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_filter_anisotropic GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transform_feedback_overflow_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_multiview_texture_multisample GL_EXT_multiview_timer_query GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset_clamp GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_image_load_store GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shadow_lod GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_R8 GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_EXT_window_rectangles GL_EXT_x11_sync_object GL_EXT_import_sync_object GL_NV_robustness_video_memory_purge GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_context_flush_control GL_KHR_debug GL_EXT_memory_object GL_EXT_memory_object_fd GL_KHR_parallel_shader_compile GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_EXT_semaphore GL_EXT_semaphore_fd GL_KHR_shader_subgroup GL_KTX_buffer_region GL_NV_alpha_to_coverage_dither_control GL_NV_bindless_multi_draw_indirect GL_NV_bindless_multi_draw_indirect_count GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_square GL_NV_command_list GL_NV_compute_program5 GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_draw_texture GL_NV_draw_vulkan_image GL_NV_ES1_1_compatibility GL_NV_ES3_1_compatibility GL_NV_explicit_multisample GL_NV_feature_query GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_internalformat_sample_query GL_NV_gpu_program4_1 GL_NV_gpu_program5 GL_NV_gpu_program5_mem_extended GL_NV_gpu_program_fp64 GL_NV_gpu_shader5 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_query_resource GL_NV_query_resource_tag GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_atomic_counters GL_NV_shader_atomic_float GL_NV_shader_atomic_int64 GL_NV_shader_buffer_load GL_NV_shader_storage_buffer_object GL_NV_shader_subgroup_partitioned GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_rectangle_compressed GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_uniform_buffer_unified_memory GL_NV_vdpau_interop GL_NV_vdpau_interop2 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_attrib_integer_64bit GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NV_gpu_multicast GL_NVX_progress_fence GL_NVX_gpu_memory_info GL_NVX_nvenc_interop GL_NV_shader_thread_group GL_NV_shader_thread_shuffle GL_KHR_blend_equation_advanced GL_OVR_multiview GL_OVR_multiview2 GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum
2020-07-13 12:40:45.175 T:140296047700096 DEBUG: GL: ConvolutionFilterShader: using gl_convolution-4x4.glsl defines:
#define HAS_FLOAT_TEXTURE
#define XBMC_STRETCH 0
2020-07-13 12:40:45.176 T:140296047700096 ERROR: GL: Error compiling pixel shader
2020-07-13 12:40:45.176 T:140296047700096 ERROR: 0(21) : error C7506: OpenGL does not define the global type half4
0(43) : error C7506: OpenGL does not define the global type half3
2020-07-13 12:40:45.176 T:140296047700096 ERROR: GL: Error compiling fragment shader: gl_convolution-4x4.glsl gl_output.glsl
2020-07-13 12:40:45.176 T:140296047700096 DEBUG: GL: fragment shader source:
1: #version 150
2: #define HAS_FLOAT_TEXTURE
3: #define XBMC_STRETCH 0
4:
5: uniform sampler2D img;
6: uniform vec2 stepxy;
7: uniform float m_stretch;
8: uniform float m_alpha;
9: in vec2 m_cord;
10: out vec4 fragColor;
11: uniform sampler1D kernelTex;
12:
13: //nvidia's half is a 16 bit float and can bring some speed improvements
14: //without affecting quality
15: #ifndef __GLSL_CG_DATA_TYPES
16: #define half float
17: #define half3 vec3
18: #define half4 vec4
19: #endif
20:
21: half4 weight(float pos)
22: {
23: #if defined(HAS_FLOAT_TEXTURE)
24: return texture(kernelTex, pos);
25: #else
26: return texture(kernelTex, pos) * 2.0 - 1.0;
27: #endif
28: }
29:
30: vec2 stretch(vec2 pos)
31: {
32: #if (XBMC_STRETCH)
33: // our transform should map [0..1] to itself, with f(0) = 0, f(1) = 1, f(0.5) = 0.5, and f'(0.5) = b.
34: // a simple curve to do this is g(x) = b(x-0.5) + (1-b)2^(n-1)(x-0.5)^n + 0.5
35: // where the power preserves sign. n = 2 is the simplest non-linear case (required when b != 1)
36: float x = pos.x - 0.5;
37: return vec2(mix(x * abs(x) * 2.0, x, m_stretch) + 0.5, pos.y);
38: #else
39: return pos;
40: #endif
41: }
42:
43: half3 pixel(float xpos, float ypos)
44: {
45: return texture(img, vec2(xpos, ypos)).rgb;
46: }
47:
48: half3 line (float ypos, vec4 xpos, half4 linetaps)
49: {
50: return
51: pixel(xpos.r, ypos) * linetaps.r +
52: pixel(xpos.g, ypos) * linetaps.g +
53: pixel(xpos.b, ypos) * linetaps.b +
54: pixel(xpos.a, ypos) * linetaps.a;
55: }
56:
57: vec4 process()
58: {
59: vec4 rgb;
60: vec2 pos = stretch(m_cord) + stepxy * 0.5;
61: vec2 f = fract(pos / stepxy);
62:
63: half4 linetaps = weight(1.0 - f.x);
64: half4 columntaps = weight(1.0 - f.y);
65:
66: //make sure all taps added together is exactly 1.0, otherwise some (very small) distortion can occur
67: linetaps /= linetaps.r + linetaps.g + linetaps.b + linetaps.a;
68: columntaps /= columntaps.r + columntaps.g + columntaps.b + columntaps.a;
69:
70: vec2 xystart = (-1.5 - f) * stepxy + pos;
71: vec4 xpos = vec4(xystart.x, xystart.x + stepxy.x, xystart.x + stepxy.x * 2.0, xystart.x + stepxy.x * 3.0);
72:
73: rgb.rgb =
74: line(xystart.y , xpos, linetaps) * columntaps.r +
75: line(xystart.y + stepxy.y , xpos, linetaps) * columntaps.g +
76: line(xystart.y + stepxy.y * 2.0, xpos, linetaps) * columntaps.b +
77: line(xystart.y + stepxy.y * 3.0, xpos, linetaps) * columntaps.a;
78:
79: rgb.a = m_alpha;
80: return rgb;
81: }
82: #if defined(XBMC_DITHER)
83: uniform sampler2D m_dither;
84: uniform float m_ditherquant;
85: uniform vec2 m_dithersize;
86: #endif
87: #if defined(KODI_3DLUT)
88: uniform float m_CLUTsize;
89: uniform sampler3D m_CLUT;
90: #endif
91:
92: void main()
93: {
94: vec4 rgb = process();
95:
96: #if defined(KODI_3DLUT)
97: // FIXME: can this be optimized?
98: rgb = texture(m_CLUT, (rgb.rgb*(m_CLUTsize-1.0) + 0.5) / m_CLUTsize);
99: #endif
100:
101: #if defined(XBMC_FULLRANGE)
102: #if __VERSION__ <= 120
103: rgb = (rgb-(16.0/255.0)) * 255.0/219.0;
104: #else
105: rgb = clamp((rgb-(16.0/255.0)) * 255.0/219.0, 0, 1);
106: #endif
107: #endif
108:
109: #if defined(XBMC_DITHER)
110: vec2 ditherpos = gl_FragCoord.xy / m_dithersize;
111: // ditherval is multiplied by 65536/(dither_size^2) to make it [0,1[
112: // FIXME: scale dither values before uploading?
113: float ditherval = texture(m_dither, ditherpos).r * 16.0;
114: rgb = floor(rgb * m_ditherquant + ditherval) / m_ditherquant;
115: #endif
116:
117: fragColor = rgb;
118: }
119:
2020-07-13 12:40:45.176 T:140296047700096 ERROR: GL: Error compiling and linking video filter shader
2020-07-13 12:40:45.176 T:140296047700096 ERROR: GL: Falling back to bilinear due to failure to init scaler
