Full Version: Titan BINGIE MOD v1 (UPDATED - 07/24/2020)
Titan BINGIE MOD v1.0.9.mod
This is the BINGIE MOD skin of @AchillesPunks, @HugoL. With this zip we can have both the original BINGIE skin from @Cartman.dos and the BINGIE MOD Skin from @AchillesPunks, @HugoL. Just note apply the NETFLIX COLOR THEME in Settings by @AchillesPunks. enjoy it
Link Below
Titan BINGIE MOD
First I wanted to Thank @Cartman.dos for creating the backbone for this skin & All users that are helping and contributing to continue this skin mod.
Required Repositories :
- BINGIE Repository: BINGIE Repository is the home of the Bingie skin and all its necessary add-ons.
THIS REPOSITORY IS THE ONLY REPOSITORY YOU NEED IN ORDER TO INSTALL THIS SKIN AND THE MOD ABOVE
Additional Add-ons: (not required)
- Artwork Beef : (Get from Rector Stuff Repository, also available on bingie repo)
- Up Next - is integrated and is used to watch next episode.
- BINGIE Movie Genre Icons - Install and set as resource in general settings to have the green bricks shown in images on genres and category widget.
Note: After you install the REPOSITORY and SKIN from @Cartman.dos Download my Mod from zip above and install.
Change Log
1.09
• Added Snow animations for homescreen. Found under Seasons Greetings in Homescreen Layout.
• Brought back the Fixed frame. Do not select if you have multiple widget styles as it will not work properly. Found under Widgets in Homescreen layout.
• Improved Spotlight corner image diffuse mask (hides the left edge a little better)
• Added option for a New spotlight corner image. This is similar to Achilles previous spotlight corner where you a get a nice big centre focus on the fanart. Don’t select if you prefer the whole fanart image fitting the spotlight. Found under spotlight options in Homescreen layout.
• Added back and tidied up the original font for foreign language support or if you just want to mix it up. Looks pretty good now! Found under the interface settings labelled as “Original”.
• Option for either red or white sublabel icons (top250/Director icon) on Spotlight Content and also home/bingie library views. Found under their respective parent settings in Homescreen layout.
• Fixed the red circle details icon not showing in Bingie library poster view intermittently
• Fixed intermittent problem with top250 sublabel icon incorrectly displaying in Bingie TV library
• Improved diffuse behind Netflix logo on Home for better widget visibility behind the logo.
• Changed the logos for RT/IMDB/TVDB details row. Also added a white logo version setting under the parent setting. Found under Details Options in Homescreen Layout.
• Fixed studios not showing with RT/IMDB/TVDB details row selected.
• Added New Footers for Home and Library Bingie views which now includes Rotten Tomatoes Fresh certification, Oscar Wins and Rotten Tomatoes Audience. IMPORTANT NOTE: RT Audience has it’s own toggle setting. Technically, it’s just a default database rating. Only enable it if you have set or intend to set RT Audience as your default database rating for movies (normally done with Universal Media Scraper) and all your movies have been scraped with Audience as the default rating.
• New footers include a color option, a white logo option and text only option – Found under Footers in Homescreen Layout.
• Added a new Plot & Critics footer that that also includes votes. Please note: The RT Audience rating here does not require it to be the default rating. It does however require that you have you this info scraped since this info is not available via skinhelper! A couple of methods I am aware of: UMS scraper or even simpler, Metadata Editor addon. The latter can quickly update all your ratings & votes.
Changelog 1.0.8
Spotlight
-New brighter spotlight widget diffuse.
-Spotlight Widget now hides plot on idle (with a slide animation)
-New metadata sublabel on spotlight widget (and on home & Bingie views) Spotlight sublabel now includes top 250 on IMDB and Director metadata (Director metadata is only displays on films and only for spotlight, not bingie views). Can be disabled via (Settings>Homescreen Layout>Details Options).
Menu
-New menu icons for sideblade and slim menu. Increased sideblade menu width to allow for longer labels (had to alter the submenu position for this to work so it sticks out further than usual.
-General tidy up of sideblade menu and slim menu/indicator.
-Menu now displays a max of 6 short cuts/hubs at any time, so you can have as many as you like without affecting the look of the menu.
Details Row
-New Option fake resolution codec. If enabled and if your resolution and audio metadata is missing, a fake “Ultra HD 4K” flag will appear.
-New Option for displaying TV show status (ended, cancelled or continuing)
-New option for Audio Codecs to display only the Atmos metadata (like Netflix) providing you have the existing metadata and when Audio Codecs are enabled.
-Removed all other audio codec logos. It’s only text & flagbox now for non ATMOS audio Codecs
-Added TVDB rating to the IMDB/RT details row option (RT for films, TVDB for shows)
-General details row tidy up
OSD
-Added the option to switch between either ClearLogo or ClearArt when OSD is paused.
-Added option to switch between ClearLogo or ClearArt for OSD infopanel
-Added option to remove the current time, start time and duration of movie on OSD
-Added option to have jump indicator show when skipping video scenes.
-Added option to remove the discart from OSD Infopanel
-Changed the diffuse on the OSD infopane to help highlight the infopanel better.
Other changes
-New Circular Navigation option – Removed access to the old version. New option keeps the same layout as noncircular navigation. Sideblade Menu access is on
Back command only. We will hopefully implement menu access from position 0 On Left in the next update. Option found via (Settings>Homescreen
Layout>Widgets).
-New Total video count in bingie library views next to header.
-Fixed bug with widget focus position changing when more than 28+ widgets are loaded.
-Fixed widget header scrolling when Plot Scrolling is enabled.
-Changed the left side diffuse on home so menu icons are more visible when there is a widget directly behind it.
-Adjusted widget heights for bingie library views (poster and landscape)
-Tidied up Continue watching widget
-Tided up Plots & Critics in Video Info dialogue
-Tidied up Cast in Video Info dialogue
-Added a season greetings Snow effect option Settings>homescreenlayout>seasons greetings
Changelog 1.0.6
- Fixed diffuse not clearing with Netflix logo when remove option is selected.
- Fixed Video Info dialog plots & critics text merging with with sublabel/details row
.- Fixed progress bar disappearing on Continue Watching widget??
- Improved Content Spotlight widget diffuse
- Improved spotlight corner diffuse
- Changed plot visibility in views - scrape short Plot Outlines for much better looking views or you’ll have large blocks of text that cut off as opposed to the nice 2 or 3 line Netflix plot outlines
- Improved Text titles
- Improved Spotlight details Row inc. removed all non UK icons from details row, added option to switch between UK Icons or classic flag box/text MPAA.
- New options found in Details Options in Settings>homescreen layout.
- Improved spotlight details row flag boxes
- UK Icons now default to coloured, removed monochrome. Will now fallback to flag box/text where no relevant image is found.
- Anyone with US MPAA ratings can now use UK Icons without scraping UK ratings, although scraping UK ratings will provide more accurate results!
- Added Audio Codec info to Details Row. Can be disabled in Details Options in Settings>homescreen layout.
- Logos created for Dolby Digital (AC3), ATMOS, DD TrueHD. Everything else will fallback to flagbox/text
- Added UK Age rating Icon slide animation to spotlight content widget when UK Icons are enabled.
- Added option setting for a new details row style found under Details Options in Settings>homescreen layout replacing green percentage section with Rotten
Tomatoes/IMDB rating and logo. A more uniform look when clearlogos are set to off.
To do:
- Put all extras folder textures back in .xbt to ensure correct loading of textures.
**Known bugs**
- With UK Icons setting is enabled, Episode view loses the bingie mod landscape art for some strange reason!
- With UK Icons setting enabled, switching from poster to landscape in library bingie views can cause odd MPAA fallback behaviour, text displaying in front of logo. Corrects itself when leaving and returning to library view.
Changelog 1.0.5
  • Added Option to Remove the Netflix Logo on Home.
  • Removed Fixed Focus Frames.
  • Removed the Option to Disable profile picture
  • Added Enable Zoom effect on selected Widget on Home
  • Adjusted Configure Shortcuts.
  • Moved Spotlight Diffuse & Vignette to XBT.
  • Changed the Bingie Logo in xml to Netflix Logo for Home icon.
  • Sideblade menu improvements including.
  • Removed panel and focus highlights and replaced with a diffuse.
  • Font improvements including focused font is bold.
  • Red line indicator now remains static rather than incorrectly moving with focus.
  • Slim menu gets an (almost)working red line indicator. incorrectly disappears if you select the same hub twice in succession.
  • Also added option for Netflix logo at the top instead of profile name/picture.
  • Small details row improvements.
  • Straightened up the resolution/audio description, UK icon age certs.
  • New spotlight corner diffuse image too for more visibility of artwork and a more square looking diffuse as opposed to the previous rounder corner.
Thanks for your work on this skin. I use mezzmo on my PC where I put some TV shows and odd and sods that I can share to everyone in the house. I only get black backgrounds until I get into the seasons and episodes view ( here everything is good ). This happens with the mezzmo plugin and if using UPNP. Each method gives slightly different results depending on the skin, but normally gives a background of some type. Is there a way to select different B/Gs for different screens or am I being difficult.....thanks..
(2020-07-24, 05:20)tankman37 Wrote: [ -> ]Thanks for your work on this skin. I use mezzmo on my PC where I put some TV shows and odd and sods that I can share to everyone in the house. I only get black backgrounds until I get into the seasons and episodes view ( here everything is good ). This happens with the mezzmo plugin and if using UPNP. Each method gives slightly different results depending on the skin, but normally gives a background of some type. Is there a way to select different B/Gs for different screens or am I being difficult.....thanks..
Can you give me a screen shot of the issue?
(2020-07-24, 06:18)AchillesPunks Wrote: [ -> ]
When you get into the season the background and info show as normal
(2020-07-24, 07:42)tankman37 Wrote: [ -> ]
Did you press left and change view? and what screen are the images on?
Make sure you run Artwork beef and download all fanart. On the view you need to press left hit change view and select episode views. Not sure how it works on UPNP
(2020-07-24, 08:01)AchillesPunks Wrote: [ -> ]
(2020-07-24, 06:18)AchillesPunks Wrote: [ -> ]Can you give me a screen shot of the issue?
Sorry should have said...Bingie main landscape
(2020-07-24, 08:10)tankman37 Wrote: [ -> ]
(2020-07-24, 07:42)tankman37 Wrote: [ -> ]ImageImage
Run artwork beef and do the above as shown
(2020-07-24, 08:12)AchillesPunks Wrote: [ -> ]
(2020-07-24, 08:01)AchillesPunks Wrote: [ -> ]Did you press left and change view? and what screen are the images on?
Thanks, will give it a go after dinner
Wow! NEW HOME
but again, how to remove disc art from osd without changing it from xml file?
and again, i found bug
from movies > genre > and i select a genre
and when i press enter the notifcation pop up and say it to delete the movie that i press enter :V
Great work! Thanks....this is my favourite skin
One question..will future editions have a small landscape view to compliment the widget view?
@Achiless :Large Poster View with 2 widgets rows on home screen as promised?
(2020-07-24, 09:36)3500 Wrote: [ -> ]Wow! NEW HOME
Can you send me screen shots of the issues?
(2020-07-24, 11:51)spinecho Wrote: [ -> ]One question..will future editions have a small landscape view to compliment the widget view?
I will have to look into this. Generally would like to keep everything as light as possible. This is already a heavy skin. I may at sometime make some changes and create a smaller landscape, but no promises.
