Full Version: Titan BINGIE MOD v1 (UPDATED - 07/24/2020)
(2020-08-09, 11:03)HugoL Wrote: [ -> ]
(2020-08-09, 00:12)AchillesPunks Wrote: [ -> ]
(2020-08-08, 14:08)spinecho Wrote: [ -> ]Thanks for reply.
I've checked in the (think it's) extras folder and the colourful bbfc png are there.
I'm probably wrong as I'll admit I have no idea!
I'll downgrade back to original mod for now l.
I just checked and the correct code has been uploaded to the GitHub. There are small changes I have not fixed yet but UK ratings should show if you have properly scraped your media.
I think he is properly scraped. It’s scraped with a media manager so he can manage his metadata better. I just don’t personally know a way to display these icons according to his metadata.
Thanks for the continued help.
What's strange is before I updated the skin with new large logo etc. version, my Ember-scraped UK BBFC certification was showing correctly:
(Before anyone says, I know I've got 2 Flash Gordons!! One is Blu-ray and other is 4k! I have a shared mySQL database with 2 boxes, 1 1080p TV and a 4k TV so I have 2 versions of each movie)
(2020-08-09, 17:19)spinecho Wrote: [ -> ]
(2020-08-09, 00:12)AchillesPunks Wrote: [ -> ]I just checked and the correct code has been uploaded to the GitHub. There are small changes I have not fixed yet but UK ratings should show if you have properly scraped your media.
In the extras/MPAA folder can you rename all png's by first replacing the "rated" with "UK" from all the file names.  eg. UK 12.png.
Restart/reload and check your movies specifically for any icons showing up.
If this doesn't work, try removing the "UK" part so it's just the rating and restart/check again.  Report back.
(2020-08-09, 18:55)HugoL Wrote: [ -> ]
(2020-08-09, 11:03)HugoL Wrote: [ -> ]I think he is properly scraped. It’s scraped with a media manager so he can manage his metadata better. I just don’t personally know a way to display these icons according to his metadata.
Apparently, I don't have enough credibility yet to edit posts and I also have a posting limit I'm about to reach for the day!
Ignore the above, and I'll save you some time and few other naming conventions to try.
 Keep only 7 icons in your MPAA folder (since we are trying 7 different naming conventions and are going to try them all at the same time) and make sure they are different pictures
so have a U,PG,12, 12a,15,18 andan r18 in the folder.
Now rename each of the 7 icons giving each one, one of the following file names exactly as I have written.
Now, reload skin or restart kodi and then go to any of your movies with a certificate of 15 and see if any of the icons show up. If one shows up, check with naming convention you used for that icon and then rename all your icons with the appropriate naming convention.
I just updated and when I scroll the widgets down, they go up more and more
(2020-08-09, 19:36)HugoL Wrote: [ -> ]
(2020-08-09, 17:19)spinecho Wrote: [ -> ]Thanks for the continued help.
Will do...thanks again for your help
Tried your suggestion and unfortunately it did not work. Still have a blank space where the rating should be.
Thanks for trying, though.
New update:
Old version:
(2020-08-10, 00:21)spinecho Wrote: [ -> ]
(2020-08-09, 18:55)HugoL Wrote: [ -> ]In the extras/MPAA folder can you rename all png's by first replacing the "rated" with "UK" from all the file names.  eg. UK 12.png.
New update:
Old version:
Ok but did you actually try a 15 cert film since the file names I have you would only show up on a 15 cert
(2020-08-09, 19:42)shkop Wrote: [ -> ]I just updated and when I scroll the widgets down, they go up more and more
 Yep, I just noticed that too. Every time you you move down to the next widget the position, the height of the widget increases and continues to increase.
(2020-08-10, 00:31)HugoL Wrote: [ -> ]
(2020-08-09, 19:36)HugoL Wrote: [ -> ]Apparently, I don't have enough credibility yet to edit posts and I also have a posting limit I'm about to reach for the day!
New update:
Old version:
Sorry, should've been more specific.
Instead of using a 15 certificate, I changed all 7 UK icons/png in mpaa folder to 12 rating using your nomenclature as the first movie showing (Flash Gordon) is a 12 and I also tried several 12 rated movies ;-)
Unfortunately didn't work. :-(
I checked a movie nfo created by Ember and saw that the rating was: UK:12 in <mpaa> & <certification> code.
This worked om earlier mod version, so I tried renaming some of the icon/png in mpaa folder to UK:12, Rating UK:12 etc as you suggested above (swapping the hyphen for colon).
Still did not work.
Any further help would be greatly appreciated :-)
(2020-08-10, 02:13)HugoL Wrote: [ -> ]
I'm aware of the issue. I'll upload the original file until I get all the bug's out. The adjustment to the poster in one XML is effecting the movement for the rest.
I'll upload the original tonight, but I can not fix until Wednesday. I'm at work for the next three days.
(2020-08-10, 07:58)AchillesPunks Wrote: [ -> ]
I fixed it send me your email
(2020-08-10, 08:13)trkselim Wrote: [ -> ]
(2020-08-10, 02:13)HugoL Wrote: [ -> ] Yep, I just noticed that too. Every time you you move down to the next widget the position, the height of the widget increases and continues to increase.
I sent you a private message with my Email.
(2020-08-10, 11:15)AchillesPunks Wrote: [ -> ]
(2020-08-10, 07:58)AchillesPunks Wrote: [ -> ]I'm aware of the issue. I'll upload the original file until I get all the bug's out. The adjustment to the poster in one XML is effecting the movement for the rest.
Check your email
@AchillesPunks  : Reminder for Large Picture View ?
(2020-08-10, 12:25)nazim12 Wrote: [ -> ]@AchillesPunks  : Reminder for Large Picture View ?
I'm a little closer but will not be until Wednesday till I can start editing it again. You will only be able to use this layout for the 3rd widget on the Home screen for right now. So you will set the layout for the 3rd row to Highlight Layout.
