(2020-11-20, 15:47)Silviastone Wrote: [ -> ]First of want to say what a great skin this is.
I've got one issue so far while using and couldn't find if anyone else posting the same problem or not. For example, from home menu I select a show or movie from recently added widget which takes me to the list that displays more episodes, play trailer, full screen etc.
If I click on Plot & Critics it will show me that screen but now there is no way to go back to the previous screen. All I can do is back out to the home menu and anytime now I click any movie or show it will take me straight to the Plot & critics page for any movie or show. Which means I'm stuck being able to forward or back correctly and must restart kodi to get back to normal scrolling and being able to play something.
I've tried different keyboard buttons on my minix neo remote and I'm on nvidia shield.
I'll look into this later today. I'll test it out and see if I can create the same issue.
Ok I can confirm this behavior. Very annoying I'm just glad a reboot fixes the problem. After I rebooted I can't get it to do it again.
If I reboot kodi and do the same sequence I get into the same issue. What happens when you go to plot & critics and how to you get back to the previous screen and not the home menu?
(2020-11-20, 18:05)Silviastone Wrote: [ -> ]If I reboot kodi and do the same sequence I get into the same issue. What happens when you go to plot & critics and how to you get back to the previous screen and not the home menu?
I always use the Back action with no issues but I just noticed you can also return to the screen using the Left action which may be a problem under certain scenarios.
Can you give me your exact sequence starting from the moment you enter plots & critics?
(2020-11-20, 18:10)HugoL Wrote: [ -> ] (2020-11-20, 18:05)Silviastone Wrote: [ -> ]If I reboot kodi and do the same sequence I get into the same issue. What happens when you go to plot & critics and how to you get back to the previous screen and not the home menu?
I'll look at the xml in a bit for the cast and how it works. I wonder what the back action looks like in the xml for the return option. I just turned on the computer and I'm looking at the custom containers right now.
HugoL, I found some really good info for the skin shortcuts on how it's implemented into the skin.
(2020-11-20, 17:22)cscott1 Wrote: [ -> ] (2020-11-20, 15:47)Silviastone Wrote: [ -> ]First of want to say what a great skin this is.
So I just managed to recreate this issue by sheer luck. After trying everything I could think of, I decided to randomly tap my touchscreen while in Plots & Critics and then I found the bug.
So I enabled mouse support to pin down the issue. It seems that right click on mouse recreates this issue.
Silviastone Do you both have the mouse setting enabled by any chance? This needs to be disabled.
(2020-11-20, 18:42)AchillesPunks Wrote: [ -> ] (2020-11-20, 18:10)HugoL Wrote: [ -> ] (2020-11-20, 18:05)Silviastone Wrote: [ -> ]If I reboot kodi and do the same sequence I get into the same issue. What happens when you go to plot & critics and how to you get back to the previous screen and not the home menu?
@HugoL, I found some really good info for the skin shortcuts on how it's implemented into the skin.
Sounds interesting. What sort of skin shortcuts thingys??
We really need to figure out how to get TMDB helper integrated. I noticed it has a ListItem.Oscar_Wins and I want it. I've done it with skin helper but it's painful since it only has Awards rather than limiting it to Oscars. I had to use a lot of variables and visibility conditions for it to only display Oscar wins and I can't guarantee it's totally accurate. Although, everything I've checked so far seems to be accurate so maybe it is!
This film does have 11 oscar wins for example so it seems to be working as it should. It just shouldn't be this long winded to implement.
(2020-11-20, 18:48)HugoL Wrote: [ -> ] (2020-11-20, 17:22)cscott1 Wrote: [ -> ] (2020-11-20, 15:47)Silviastone Wrote: [ -> ]First of want to say what a great skin this is.
@Silviastone Do you both have the mouse setting enabled by any chance? This needs to be disabled.
I'll check when I get home if I have mouse support enabled as well. I don't know why I would I was using a similar setup as Silvia Nvidia Shield with a Mecool Q8 remote.
Hi there,
in Skin Settings > General sking Settings > Enable mouse and touch support is disabled.
I've just tried to Enable mouse and touch support and have the same issue with it enabled or disabled.
FYI: I am on an nvidia shield using a Minix Neo Mouse, which has a touch pad and a back button along with a keyboard on the back. It seems this is the only area of the skin that I've run into issues with navigation.
(2020-11-20, 19:01)HugoL Wrote: [ -> ] (2020-11-20, 18:42)AchillesPunks Wrote: [ -> ] (2020-11-20, 18:10)HugoL Wrote: [ -> ]I always use the Back action with no issues but I just noticed you can also return to the screen using the Left action which may be a problem under certain scenarios.
Top 250 looks great can you share texture file
(2020-11-20, 20:01)Silviastone Wrote: [ -> ] (2020-11-20, 18:48)HugoL Wrote: [ -> ] (2020-11-20, 17:22)cscott1 Wrote: [ -> ]Ok I can confirm this behavior. Very annoying I'm just glad a reboot fixes the problem. After I rebooted I can't get it to do it again.
Hi there,
Interesting, now that I have enabled, closed out of Kodi, disabled mouse and touch support and closed out of Kodi, it looks like the left direction on the touch pad now let's me go back to the previous screen from Plots & Critics. So for now problem seems solved with those steps.
(2020-11-20, 20:01)trkselim Wrote: [ -> ] (2020-11-20, 19:01)HugoL Wrote: [ -> ] (2020-11-20, 18:42)AchillesPunks Wrote: [ -> ]I'll look at the xml in a bit for the cast and how it works. I wonder what the back action looks like in the xml for the return option. I just turned on the computer and I'm looking at the custom containers right now.
That's something me and @
HugoL created and will add it to the next update.
(2020-11-20, 20:06)Silviastone Wrote: [ -> ] (2020-11-20, 20:01)Silviastone Wrote: [ -> ] (2020-11-20, 18:48)HugoL Wrote: [ -> ]So I just managed to recreate this issue by sheer luck. After trying everything I could think of, I decided to randomly tap my touchscreen while in Plots & Critics and then I found the bug.
Hi there,
No idea what this Minix Neo Mouse is but if you're able to point and click anywhere in the skin with your remote then it's probably going to cause problems.
Great news guys. I'm so glad you started the implementation of tmdb helper in skin. @
HugoL Is there any news regarding the bug fix we talked about.
(2020-11-20, 21:51)matke Wrote: [ -> ]Great news guys. I'm so glad you started the implementation of tmdb helper in skin. @HugoL Is there any news regarding the bug fix we talked about.
Did you download the most current version of TMDb helper from the github site? It fixed a few issues I was having.
https://github.com/jurialmunkey/plugin.v...edb.helper
