Great news guys. I'm so glad you started the implementation of tmdb helper in skin. @
HugoL Is there any news regarding the bug fix we talked about.
(2020-11-20, 21:51)matke Wrote: [ -> ]Great news guys. I'm so glad you started the implementation of tmdb helper in skin. @HugoL Is there any news regarding the bug fix we talked about.
Did you download the most current version of TMDb helper from the github site? It fixed a few issues I was having.
https://github.com/jurialmunkey/plugin.v...edb.helper
Apparently, the skin needs this service monitor thing implemented in the skin.
Even though I read it on the tmdb helper wiki on GitHub, I still don’t know how to implement it to be honest!
I tried a few things and it didn’t work and I know I’m going wrong somewhere. I’ll take another look during the week or maybe Achilles can figure it out in the meantime.
(2020-11-20, 22:16)matke Wrote: [ -> ] (2020-11-20, 22:00)cscott1 Wrote: [ -> ] (2020-11-20, 21:51)matke Wrote: [ -> ]Great news guys. I'm so glad you started the implementation of tmdb helper in skin. @HugoL Is there any news regarding the bug fix we talked about.
No, no. I'm talking about a bug that skin has, HugoL knows. Some things are missing until the view change from one to another. It has my post a few pages back.
https://forum.kodi.tv/showthread.php?tid...pid2988398
Wait, isn’t this is a different issue to the picture you posted a minute ago.
This issue, I have actually fixed. You will get the icons in library view in the next update.
It’s the other issue with TMBD helper not showing MPAA and sometimes runtime details on the details row that I’m struggling with and which requires tmdb helper integration.
(2020-11-20, 22:29)HugoL Wrote: [ -> ] (2020-11-20, 22:16)matke Wrote: [ -> ] (2020-11-20, 22:00)cscott1 Wrote: [ -> ]Did you download the most current version of TMDb helper from the github site? It fixed a few issues I was having.
Great news for a bug fix in the library. Sorry my bad. I forgot we also talked about the tmdb helper bug. I know we need tmdb monitor integration.
And let's not forget this little annoying visual bug.
https://forum.kodi.tv/showthread.php?tid...pid2988433
Anyway, keep it up guys. You are doing a fantastic job.
MPAA and runtime working for me through TMDB helper with Trakt lists but not TMDb lists.
(2020-11-20, 22:56)cscott1 Wrote: [ -> ] (2020-11-20, 22:29)HugoL Wrote: [ -> ] (2020-11-20, 22:16)matke Wrote: [ -> ]No, no. I'm talking about a bug that skin has, HugoL knows. Some things are missing until the view change from one to another. It has my post a few pages back.
Yep, that’s what I gathered from earlier discussions. Couldn’t be bothered to set up my trakt so I just took it as gospel that works as expected.
And I’m kind of taking it as gospel that to fix other lists you need to implement this Service Monitor thing to get other lists working but its strange that it should work for one list and not another.
Wait a minute @
HugoL did i see a picture you have put up and you have popcorn ratings in it.
How? I've been looking into the implementation for a while. Didn't think it was up and running. Any news sir please.
Glad you guys are looking at TMDB helper implementation it would be really great and help take it to the next level! i was actually trying to implement TMDBHelper to replace extended info as its possible here, but its not somethign I can do myself easily.
Using TMDB Helper for extended info would be really great they have the whole Cast and More, Reccomended, Like this, etc all together and even better it can show movies and shows in it that are not in your library, though you wont be able to play them u can still see and view them.
https://github.com/jurialmunkey/plugin.v...ended-Info
Here is the guide written by TMDBH dev to show how to replace extended info if you want to take a look; and regarding looking at other skins to see how they implemented TMDB Helper, Auramod is a great example.
https://github.com/jurialmunkey/plugin.v...-Functions
(2020-11-21, 03:20)DROIDshield Wrote: [ -> ]Wait a minute @HugoL did i see a picture you have put up and you have popcorn ratings in it.
The popcorn rating is a personal addition. Not sure if it’s worth putting in a release.
It’s just pointing to my default database rating. I had to re-scrape again with Universal Movie Scraper, setting Rotten tomatoes audience as my default rating.
For anyone else who hasn’t done this, they’d just have their default (probably tmdb) rating showing up there with a popcorn icon!
I loaded the newest git and was playing around with adding some new widgets with TMDb helper and added the Poster details view to one of the widgets then went back and enabled vertical fixed focus and to my surprise it worked! Nice job guys... still hoping to see the top 10 Poster view at some point but this will do for now.
(2020-11-21, 17:27)cscott1 Wrote: [ -> ]I loaded the newest git and was playing around with adding some new widgets with TMDb helper and added the Poster details view to one of the widgets then went back and enabled vertical fixed focus and to my surprise it worked! Nice job guys... still hoping to see the top 10 Poster view at some point but this will do for now.
Hasn’t this one always worked with fixed focus providing the rest of the widgets are poster? Essentially it’s still just poster view.
I think the issue arises when there’s layouts of varying heights while using fixed focus. So things like landscape + poster can’t work together for example.
(2019-09-30, 00:38)spigot666 Wrote: [ -> ] (2019-09-29, 02:35)spigot666 Wrote: [ -> ] (2019-09-23, 13:14)anbessaw7 Wrote: [ -> ]@cartman.dos Thanks for the great skin and appreciate all the support you provide. Have been using this skin for a while now and the layout and functionality is ideal for my purposes. I have no intention of switching to another skin, so I wanted to know if you will/have considered supporting the Advanced Emulator Launcher addon?
I have already added my games to Bingie and out of the box - artwork (fanart) works and metadata works partially for fields that are present in both add-ons (i.e Plot, Year, Rating) but if I could get the additional information screen and auto-trailers to work - my setup would be complete!
I know this is cannot be a priority for this project - so would the above be possible through simple modification of some settings and layouts in bingie? I am willing to give it a shot but have no idea how complex it might be
....I can not change views associated with Advanced emulator launcher. No matter what view I choose it immediately reverts to list.
A video of this issue. No matter what I do, my AEL views always stay to list:
https://imgur.com/Q0ZbkaC
Anyone here have this issue? I tried the Titan Bingie and now Titan Bingie Mod, both have the same issue. I can't choose Bingie Main Poster view for AEL.
