(2020-11-26, 13:56)cscott1 Wrote: [ -> ]So made some progress yesterday with getting ratings to display in the footer. I have all the TMDB, IMDB, IMDB top 250, Rotten Tomatoes and Metacritics for my movies subsequently all these can be scraped by adding your OMDB api to the Universal Movie scraper. I have all TVDB and IMDB ratings for TV shows which are scraped from TVDB. I have only a handful of Rotten Tomato scores for tv shows I assume they are coming from the skinhelper/artwork & metadata module. Still no IMDB top 250 TV shows or Metacritics for shows. I left my Shield on when I went to work with auto rotate widgets on hoping that rotating through the widgets will help the others to appear but who knows.
You can't get RT and Metacritic for TV shows unfortunately because OMDB doesn't provide this data.
Skinhelper also can't grab RT Audience scores for movies either but since your scraping movies with UMS, if you set RT audience scores as your default database rating, the skin will be able to display it in the footers with a popcorn icon in the upcoming update. Technically, it will just display any default rating so that's why you need RT audience as a default for it to display properly. That's just a limitation with Kodi not being able to display non default ratings anywhere except the video info dialogue window. So in Plots & Critics, you will get all your other UMS non-default scraped ratings properly displayed (again, in the update).
(2020-11-26, 14:49)HugoL Wrote: [ -> ] (2020-11-26, 13:56)cscott1 Wrote: [ -> ]So made some progress yesterday with getting ratings to display in the footer. I have all the TMDB, IMDB, IMDB top 250, Rotten Tomatoes and Metacritics for my movies subsequently all these can be scraped by adding your OMDB api to the Universal Movie scraper. I have all TVDB and IMDB ratings for TV shows which are scraped from TVDB. I have only a handful of Rotten Tomato scores for tv shows I assume they are coming from the skinhelper/artwork & metadata module. Still no IMDB top 250 TV shows or Metacritics for shows. I left my Shield on when I went to work with auto rotate widgets on hoping that rotating through the widgets will help the others to appear but who knows.
I do have a few Rotten Tomato scores for tv shows The Simpsons was one I remember off the top of my head where is that coming from?
(2020-11-26, 15:05)cscott1 Wrote: [ -> ] (2020-11-26, 14:49)HugoL Wrote: [ -> ] (2020-11-26, 13:56)cscott1 Wrote: [ -> ]So made some progress yesterday with getting ratings to display in the footer. I have all the TMDB, IMDB, IMDB top 250, Rotten Tomatoes and Metacritics for my movies subsequently all these can be scraped by adding your OMDB api to the Universal Movie scraper. I have all TVDB and IMDB ratings for TV shows which are scraped from TVDB. I have only a handful of Rotten Tomato scores for tv shows I assume they are coming from the skinhelper/artwork & metadata module. Still no IMDB top 250 TV shows or Metacritics for shows. I left my Shield on when I went to work with auto rotate widgets on hoping that rotating through the widgets will help the others to appear but who knows.
All RT scores in the skin only come from skinhelper currently (and soon to be from your database if you scrape with UMS, but will only show in Plots & Critics)
So it must be coming from skinhelper and presumably OMDB but probably just an error in skinhelper or OMDB. I've got a couple of these myself.
Finally, it's working. I uninstall and re-install everything in Kodi. Now It shows Imdb, top250, Tmdb, RT, and Metacritic ratings.
I created Submenu IMDB TOP 250 by using skin helper widgets (also increases no of items to 250). How can I get count like in the "All movies" section.
(2020-11-26, 16:04)karthikm Wrote: [ -> ]Finally, it's working. I uninstall and re-install everything in Kodi. Now It shows Imdb, top250, Tmdb, RT, and Metacritic ratings.
It hasn’t been set up to show in that type of window. Only in main library menus.
How did you get the ratings to show on the right side above the widgets? Mine is under the clearlogo on the top left where the name of the movie/show is.
(2020-11-26, 19:59)Adammay20 Wrote: [ -> ] (2020-11-26, 16:04)karthikm Wrote: [ -> ]Finally, it's working. I uninstall and re-install everything in Kodi. Now It shows Imdb, top250, Tmdb, RT, and Metacritic ratings.
Skin settings > Homescreen layout > Details option > disable perfer imdb/rt ratings.
(2020-11-26, 20:17)karthikm Wrote: [ -> ] (2020-11-26, 19:59)Adammay20 Wrote: [ -> ] (2020-11-26, 16:04)karthikm Wrote: [ -> ]Finally, it's working. I uninstall and re-install everything in Kodi. Now It shows Imdb, top250, Tmdb, RT, and Metacritic ratings.
Great, I will try that out!
Also, do you know how to enable the clear logo? Mine just says the name of the show/movie in normal text and not the clear logo. I know there's a setting that you can enable that changes the clear logo to just plain text and that is turned off.
I have my fanart api key, just not sure where to put it lol
(2020-11-27, 01:04)Adammay20 Wrote: [ -> ] (2020-11-26, 20:17)karthikm Wrote: [ -> ] (2020-11-26, 19:59)Adammay20 Wrote: [ -> ]How did you get the ratings to show on the right side above the widgets? Mine is under the clearlogo on the top left where the name of the movie/show is.
You have to use artwork beef to get the clearlogos. If you don't have it it can be found under settings/skin settings/supported add-ons. After installing it then you can configure it to scrape tons of different different artwork to your library including the clearlogos.
What's going on with the fanart? I don’t get a single poster, background, clearlogo.. . It worked the last time I turned on the kodi a few days ago.
(2020-11-27, 22:45)matke Wrote: [ -> ]What's going on with the fanart? I don’t get a single poster, background, clearlogo.. . It worked the last time I turned on the kodi a few days ago.
Fanart TV must be down or something. You can still pull art from the Movie Database
(2020-11-27, 23:25)cscott1 Wrote: [ -> ] (2020-11-27, 22:45)matke Wrote: [ -> ]What's going on with the fanart? I don’t get a single poster, background, clearlogo.. . It worked the last time I turned on the kodi a few days ago.
I use tmdb helper and I have to use fanart.tv. Only through fanart.tv I get everything (clearlogos, clearart...).
(2020-11-27, 23:42)matke Wrote: [ -> ] (2020-11-27, 23:25)cscott1 Wrote: [ -> ] (2020-11-27, 22:45)matke Wrote: [ -> ]What's going on with the fanart? I don’t get a single poster, background, clearlogo.. . It worked the last time I turned on the kodi a few days ago.
I can't pull up anything from Fanart TV with artwork beef right now either this happens occasionally might be doing some maintenance to their servers or something
Finally i have bigger poster layout without loosing heights and second row widget display.
HugoL Can you check one thing? Does it work for TV shows in tmdb helper more info, extended info. It works for movies, but for TV shows I get a blank screen, without any information.
