(2020-08-11, 09:11)AchillesPunks Wrote: [ -> ] (2020-08-11, 08:17)spinecho Wrote: [ -> ]@AchillesPunks sorry, very stupid question... How do I download these from GitHub?
Front page.
Thanks... thought had to download a file directly from GitHub!
(2020-08-11, 09:58)spinecho Wrote: [ -> ] (2020-08-11, 09:11)AchillesPunks Wrote: [ -> ] (2020-08-11, 08:17)spinecho Wrote: [ -> ]@AchillesPunks sorry, very stupid question... How do I download these from GitHub?
Front page.
Let me know what you think.
why I don't have "layout for widget" in the customization of widgets?
(2020-08-11, 11:55)shkop Wrote: [ -> ]why I don't have "layout for widget" in the customization of widgets?
You need to disable fixed focus widget in vertical scrolling. Then you will have the layout option.
thank you for your reply, if I disable I end up with this:
(2020-08-11, 12:30)shkop Wrote: [ -> ]thank you for your reply, if I disable I end up with this:
Disable go skin shortcut change view then enable fixed focus frame
i am lost lol can you take a screenshot please?
ohh okk I did not understand correctly, sorry thank you for your help
the clearlogo has shrunk since the update ?
(2020-08-11, 10:41)AchillesPunks Wrote: [ -> ] (2020-08-11, 09:58)spinecho Wrote: [ -> ] (2020-08-11, 09:11)AchillesPunks Wrote: [ -> ]Front page.
Hi, Just downloaded the new update and installed/updated it.
Cannot see any changes to version 1 - ClearLogo still small and my UK ratings are the same monochromatic as original version.
