(2020-12-08, 00:10)mathu204 Wrote: [ -> ]Do I have to have bingie skin installed too? I download the repo and then installed bingie mod and it works fine, on my previous install I had bingie skin installed as well but i notice no difference yet on this fresh install with just the repo
It’s just to install the dependencies. You don’t actually need the skin
For anyone that was intrigued by that ExtendedInfoMod that hooks with TMDBHelper I mentioned earlier, after some research and A LOT of help I managed to make a TMDBHelper player for OpenInfo/Meta, so I can confirm episodes now work playing with TMDBHelper in ExtendedInfo, atleast for the sources i Tested, so u can now play an episode of Mandalorian through ExtendedInfoMod using TMDBHelper, and having the Disney+ addon.
(2020-12-08, 07:34)mathu204 Wrote: [ -> ]For anyone that was intrigued by that ExtendedInfoMod that hooks with TMDBHelper I mentioned earlier
I was following your post on Reddit and I'm happy to see you got some help! I will defenitely check it out
(2020-12-08, 07:34)mathu204 Wrote: [ -> ]For anyone that was intrigued by that ExtendedInfoMod that hooks with TMDBHelper I mentioned earlier, after some research and A LOT of help I managed to make a TMDBHelper player for OpenInfo/Meta, so I can confirm episodes now work playing with TMDBHelper in ExtendedInfo, atleast for the sources i Tested, so u can now play an episode of Mandalorian through ExtendedInfoMod using TMDBHelper, and having the Disney+ addon.
Just read your thread on Reddit good work. Hopefully the Devs will implement the code. Post up the code as you did there so they can take a look.
(2020-12-07, 11:00)AchillesPunks Wrote: [ -> ] (2020-12-07, 10:51)ecser Wrote: [ -> ]Menu focus changes when navigating back to menu
First of all: thank you for your fantastic work.
There is a strange behaviour which I can't fix now: I open kodi, browsing the Home widget. When I go back to menu (left arrow) the "Live TV" menu is focused. Similarly, this happens with the other menu items too: when I get out of the widget, a different menu item is focused. Is there a setting to switch this fuction off and use a traditional menu logic: When I am in the Home widget and go back to menu (left arrow) the "Home" menu item should be focused?
Thank you.
Does the menu icon have a red line under it? If so that should be the widget you are in. Now if you have the menu open and scroll up or down you will still have the red icon on the menu you are in but the text will be highlighted on where you left off.
Yes, the menu icon has a red line, this is ok. The strange thing is, when I come out of a widget with the left arrow button, the menu opens and a
different menu item is higlighted, not the one I was in. I would expect following behaviour: when I leave the Home widget, the menu opens and Home menu item is higlighted and the home icon marked with red line. But it works differently, I posted screenshots about this yesterday.
(2020-12-08, 20:31)nazim12 Wrote: [ -> ]How to resize New Footer Ratings & Studio Logo icons , Its very small in size .
https://i.postimg.cc/d1Z5VFKF/image.png
In includesfooter.xml search for "new footer". All the image and label controls are there all neatly labelled. But if you still require help I suggest you switch back to the old footer instead. There's over 30 controls in this footer, most will need adjusting depending on what you're trying to achieve and that's not something I'd be interested in assisting with right now.
(2020-12-08, 22:29)HugoL Wrote: [ -> ] (2020-12-08, 20:31)nazim12 Wrote: [ -> ]How to resize New Footer Ratings & Studio Logo icons , Its very small in size .
OK but older footer doesn't have popcorn rating icon.
(2020-12-07, 17:35)minhgi Wrote: [ -> ] (2020-12-07, 06:49)AchillesPunks Wrote: [ -> ] (2020-12-07, 03:24)HugoL Wrote: [ -> ]I don’t think that title has RT audience set as default right? Looks like your default is still either TMDB or IMDB and the popcorn icon is just displaying one of those defaults. Or is that just a coincidence?
I think it may be just a coincidence for the popcorn rating. I'll check it out in a bit.
Yeah. I'm quite curious how to get that popcorn rating. Seem a better rating icon compare to the others? lol. Is possible to get that as part of the normal rating display?
Got it to show with a few videos using the UMS scraper. Thank again.
(2020-12-08, 23:08)nazim12 Wrote: [ -> ] (2020-12-08, 22:29)HugoL Wrote: [ -> ] (2020-12-08, 20:31)nazim12 Wrote: [ -> ]How to resize New Footer Ratings & Studio Logo icons , Its very small in size .
You're not even getting the popcorn rating now as far as I can see. For the home and library footer, it's only a popcorn rating (RT Audience) if you've set that as your default rating with UMS and then rescraped your movies to put it in the default position.
Looks like your default rating is set to IMDB from your picture. I can tell because the green % liked is the default rating position which is the same as the (decimalised) IMDB score, and now it's also your popcorn rating too. So you're actually displaying the IMDB rating 3 times in this picture.
Avengers should be sitting around 90% for audience. You can quickly check the proper score by going to the Plots & Critics footer which will display the proper audience rating regardless of whether your RT audience scraped rating is in the default position (as long as you have this info scraped).
Regardless, it's a moot point, it doesn't matter now because a proper popcorn rating for home and library is on it's way from TMDB helper, along with Trakt & TMDB ratings for both TV and film. I've "sort of" integrated TMDB Helper now.
(2020-12-09, 00:55)HugoL Wrote: [ -> ] (2020-12-08, 23:08)nazim12 Wrote: [ -> ] (2020-12-08, 22:29)HugoL Wrote: [ -> ]In includesfooter.xml search for "new footer". All the image and label controls are there all neatly labelled. But if you still require help I suggest you switch back to the old footer instead. There's over 30 controls in this footer, most will need adjusting depending on what you're trying to achieve and that's not something I'd be interested in assisting with right now.
Looks like your default rating is set to IMDB from your picture. I can tell because the green % liked is the default rating position which is the same as the (decimalised) IMDB score and its now also displaying alongside your popcorn rating too. So you're actually displaying the IMDB rating 3 times in this picture.
Ohh youve gotten Trakt ratings! very nice!!
I have a question how does your guys UpNext addon notification appear in your library? Bc the Fancy one, does not look that nice, it looks really clean in other skins like Auramod and Arctic Horizon, im not sure if i have something wrong on my end or its a visual bug but is it supposed to look like this? The simple one looks cleaner and I have set on that, but the only thing that I think it could use is add the image of the next episode. Fancy should do this on other skins but not in TitanBingieMod, again I might just have mine set up wrong would u guys mind sharing what yours looks like?
2. I have some shows or episodes where I assume there is no TVDB rating bc it shows 0.0, is it possible to make it so this rating doesnt show up on the footer if its a 0.0? I doubt any show, episode or movie has been ever fully rated a 0.0 anyway unless i am wrong, in which case maybe if there is no rating for the show/ep/movie available can it just not show up.
https://imgur.com/a/p4w7xvK
Are you going to make TMDB Helper a Dependency or a Supported addon? a replacement for skin helper or just an addition to the skin? Looking down the road to a not so far away future with Matrix right around the corner. Honestly I'm a lil confused by it all, will Python 2 addons still work going forward or does everything have to to be updated to Python 3 to work with kodi 19? As far as I know Marcelveld is long gone and I think Cartman made some fixes to Skin Helper but aside from him popping in to say hello a few weeks ago I don't think he's doing anything with it now. So unless someone steps up I think its on the chopping block. Do you guys @
HugoL and @
AchillesPunks have a plan going forward? I know you guys are fairly new to skinning, hard to tell by the user you guys are doing a phenomenal job just curious to what the future holds for us.
(2020-12-09, 01:31)mathu204 Wrote: [ -> ]I have a question how does your guys UpNext addon notification appear in your library? Bc the Fancy one, does not look that nice, it looks really clean in other skins like Auramod and Arctic Horizon, im not sure if i have something wrong on my end or its a visual bug but is it supposed to look like this? The simple one looks cleaner and I have set on that, but the only thing that I think it could use is add the image of the next episode. Fancy should do this on other skins but not in TitanBingieMod, again I might just have mine set up wrong would u guys mind sharing what yours looks like?
1. Can't answer that, I don't use it.
2. Good idea, I've just implemented that.
(2020-12-09, 14:47)cscott1 Wrote: [ -> ] (2020-12-09, 00:55)HugoL Wrote: [ -> ] (2020-12-08, 23:08)nazim12 Wrote: [ -> ]OK but older footer doesn't have popcorn rating icon.
Are you going to make TMDB Helper a Dependency or a Supported addon? a replacement for skin helper or just an addition to the skin? Looking down the road to a not so far away future with Matrix right around the corner. Honestly I'm a lil confused by it all, will Python 2 addons still work going forward or does everything have to to be updated to Python 3 to work with kodi 19? As far as I know Marcelveld is long gone and I think Cartman made some fixes to Skin Helper but aside from him popping in to say hello a few weeks ago I don't think he's doing anything with it now. So unless someone steps up I think its on the chopping block. Do you guys @HugoL and @AchillesPunks have a plan going forward? I know you guys are fairly new to skinning, hard to tell by the user you guys are doing a phenomenal job just curious to what the future holds for us.
It's just going to be supported, I'm definitely not going to try and replace skin helper services. I'm using it to replace the current RT audience rating (so you don't need to scrape it in the default position), to get TMDB ratings for TV shows and also to add trakt ratings.
And I'll probably use it implement some metadata, maybe in a sublabel or the additional details red circle icon section. Since TMDb helper has a separate call for Oscars and Oscar nominations you can have something like "[title] was nominated for [x] academy awards and won [x] in [year]" for example which would help fill out your additional details section since I know that was a gripe of yours.
